mitsubishi 1.6 v6 got such thing ka?
raja_emeperor
raja_emeperor
741
28
yes..got..but engine are not powerfull, u will regret once u install it bro.better put 4g91 1.5 twincam.
if talking talking bout cruising on h/way, ppl said its better, for me still 4g91 is the best la.
GT_AUTO
GT_AUTO
3,503
71
1,648
K.Trg
www.facebook.com
yup,there is a 1.6 v6 engine.code is 6A10.yup,it's not powerful.it for cruising.the
engine is heavy.
jijoe12
jijoe12
20
the 1.6 v6 can upgrade ka? transplant mivec head in and bolt on twin turbo?
fatbusterd
fatbusterd
315
4
klang n brunei
yup it is heavy...
but i`ve try a v6 1.6 dat is ok...
no speed cut...
try wit a another 1.6v6..
d other 1 was very down...
im not sure bout difrence..
try wit a putra 300mtr...
1car hndcap...both stock stndrd
till finishing left d putra 1 1/2 car..
retry...level strt..
same...1/2 car gap...
even d owner dont believe dat his v6 can run...
dis engine is for sale...
if u wan u daily driving ,fuel con is ok...
if u wan to upgrade then bttr a 4g91,92,93
pm me if u wanna no more
esthapo
Trail Bomber
esthapo
Trail Bomber
796
186
1,543
Sister'sBedroom
Dat 6A10 so heavy lar 4 1.6 engine....better go 4 4G91 twincam or 4G92 Mivec lar if u want some performance n powahh...
GT_AUTO
GT_AUTO
3,503
71
1,648
K.Trg
www.facebook.com
yup it is heavy...
no speed cut...
maybe the putra engine is weak leh....hehehe..
popout
popout
366
my friends say that if 6A10 with 4G92 gearbox the power will be superb is that truth??
WESeleventhirty
WESeleventhirty
23
6a10 is heavy kah?. goddamn la...so performance wise quite sucky la?
my mech say the halfcut is arnd 4.5 k? what about mivec? my engine jamnation plan will be soon :proud: . now wanna search for cheap but potential engine la..my base is 1.3.
evo3
evo3
1,794
24
4G93T GSR is the best option but i wonder ur car pass the puspakom test or not as if i'm not mistaken, proton cars these day are not allowed to have turbo engine. correct me if i'm wrong
mag9556
mag9556
2,771
43
1,648
Not just performance.. FC also follow sucks.. but nice for h'way use...:burnout:
WESeleventhirty
WESeleventhirty
23
man. so the best engine for my 1.3 car ia a mivec ka?...theres some other 1.6 non mivec engine but rare kan.? its been posted in a thread amonth ago if i'm not mistaken.what about it
alonso
alonso
913
go to mivec lorr if u got extra budget and good performance for n/a engine somemore.....4g91 performance same like 1.5 soch only just got a bit diff compare to mivec..
raja_emeperor
raja_emeperor
741
28
who say 1.5 doch are same to soch? lot of diffrent bro in term of power and FC. engine smoother and powerfull than soch.
GT_AUTO
GT_AUTO
3,503
71
1,648
K.Trg
www.facebook.com
91 n 15 r different engine.91 is a lot more powerful like raja said.15 churn out
88hp while 91 rated at 110hp.
tofu_manic
tofu_manic
1,342
91
1,648
actually there is also a 4g15 dohc, but quite rare n from japan....not same as 4g91...
raja_emeperor
raja_emeperor
741
28
if u talking about rare engine, there is 1.3 soch (MVV) Vertical vortex from mitsu.power full engine lor...hard to find. power is around 95hp stock. highly rev engine. i heard r3 using this engine for merdeka endurance for their satria r3.
btw...if u wan n/a, then go for mivec 1.6(4g92) or 1.5(4g91 doch).all depend on your budget and power that u wan.
if force induction, u can choose mirage(1.6) 4g61,evo/vr4(2.0) 4g63 or gsr(1.8) 4g93t.
but if i were u, i will choose mivec la...then rojak with 1.8blok.so it will become mivec 1.8! ahahaha!!!! if u wan 1.8 blok with custom form, u can pm me. ehehehe!!!
SkYwAlKeR
Over 10,000 RPM!
SkYwAlKeR
Over 10,000 RPM!
10,138
300
3,183
ePoh ~ malacca
MVV Engine
In 1992, Mitsubishi began producing the MVV (Mitsubishi Vertical Vortex) engine. The lean-burn MVV engine can achieve complete combustion with an air-fuel ratio as high as 25:1, whereas conventional engines require 14.7:1. The result is 13% better fuel economy at 40km/h over a conventional engine powered vehicle. This 13% improved fuel economy means lower CO2 emissions, a major factor in global warming.
The MVV engine utilizes a twin intake port design to induce vertical vortices inside the cylinder. The result is a barrel pattern of stratification ensuring in the process that the influxes from the two intake ports do not mix together until the end of the compression stroke. The design of the compression chamber ensures the total collapse and transformation into small-scale turbulence of the vertical vortices at the end of the compression stroke. The turbulence and the mixture stratification provide accelerated and stable combustion.
The MVV engine is equipped on some Minica (Towny) and Libero (Lancer Station Wagon) models in Japan.
MiOKu
MiOKu
136
yup... my friend using the 1.6 v6... not tat powerful but the sound is really superb... especially when he start the car...even the engine bay looks nice...
mag9556
mag9556
2,771
43
1,648
nowdayz 4g engine also can produce such starter kick sound liao...hehe
parawisata79
parawisata79
290
yup, it's true raja_emeperor, engine not so powerfull if u r talking about performance.. cruising on highway yes, if u alway driving from JB to Bkt Kayu Hitam I think u will feel the respond.
One more thing about the maintenance, few of mechanic will take a longer time to service ur car xpecially change the s/plug. Timing belt also take few days to do it. See the space when u modi to V6 eng, even ur hand also no space to get in..
few of my fren also regred now install the eng. It also same capacity 1.6, only the eng is big.. so like like gempak la..
up to u la bro.. if u want performance I suggest 4G91 or Mivec is better.. :driver:
cheers..!!
GT_AUTO
GT_AUTO
3,503
71
1,648
K.Trg
www.facebook.com
not the starter sound la mag.the v6 engine emit different sound from 4 cyclinder
engine.the sound very cun 1.the starter 1 ez only to do.just change the
starter to the v6 1,kau tim already.....:burnout:
boyzone
boyzone
2,669
38
VR4 starter also come with this sound.
If always go to high way travel.. don't use mivec gearbox if u gonna to mivec engine, u might face a very high fuel consumption. This because mivec is running with close ratio and high Final Drive setting.
WESeleventhirty
WESeleventhirty
23
waa thanx soo much for ur info guys! really appreciate it! now i need 2 go and check around for halfcut prices...or simply ask the mech. to carik for me. which one better? go findout urself or be plain lazy? and howmuch u should allocate for engine trouble shooting after conversions? some say usually 500 also ok adi. but it sure depends on the engine condition rite?
kob3bryant
kob3bryant
484
for your info
4g15 dohc version is lately production from mitsu.unlike those 4g15 in malaysia made car.their dohc version equiped with mivec tech.now got 4g15dohc mivec turbo already.equiped into Colt turbo.this is the same engine with the mercedes smart car turbo.manu by mitsu also.
mag9556
mag9556
2,771
43
1,648
for your info
confirm arh.. can load into Wira or not?
Sep 11, 2009
Kuantan
for me I'm prefer V6 1.6 better for performance and for the cheapest engine....
i'm already use 4g91... it's sucks!!!!
no power....my v6 really don't have speed cut!!
---------- Post added at 09:34 PM ---------- Previous post was at 09:30 PM ----------
4g6x its twin cam 4g1x its sohc...:biggrin:
raja_emeperor
raja_emeperor
741
28
wah! after 1 year resting posting any cooment iz ZTH, today someone ring my bell!
all jap engine got speed cut my fren...easy only to by pass,only one wire behind the meter with the 0 clip at the end, unsrew it, secured it with tape(to ensure in wont touch to other terminal) walla it is done.
1.5doch is good engine, easy mods can become monster! eg extractor mivec and open pod filter!see it cathing up top speed in highway with gsr!ahahahhaha!!
v6 ok if cruising in highway and the fuel consuption can kill if run inside town...from there u will fell this engine abit sluggish.
Sep 11, 2009
Kuantan
la...
Raja..
I told u mine Engine originally from halfcut...put fullset of h/cut wiring...auto g/box..
no engine cut can run until 8k rpm and speed can run out meter...
stock engine...
last my 4g91 very lousy....x power langsung...selalu overheat...
raja_emeperor
raja_emeperor
741
28
nvm..if u feel v6 1.6 is powerfull than stick with it...
for me 1.5 twincam have a lot of potential to play with, less maintainance compared to v6...
end of day u will realized which is the best and less headache...
if want more power...go for evo or vr4 la...habis cerita...
then u will thirst of power! then go play other car plak...never ending story....
Yong_5290
Yong_5290
3,637
49
Klang
hotmail.com
this thing is like comparing sr20 and rb20...which 1 better...both 2.0....1 4piston 1 6piston...1 got lots of parts....1 sound much nicer
the v6 sure emits wonderful xhaust note...but the overall balance of the car i think just sucks...since all the weight all in the front wheel plus u r running fwd...so the weight distribution of the car mah like fron 70-30 rear...o mayb 80-20 for satria
boyzone
boyzone
2,669
38
My staria had been loaded 6A10. Very bad on handling due to understreet.:banghead:
Boy_HS
Boy_HS
37
sabah
6a10 so heavy la bro... i've been used this engine but xde ong la... better u go to mivec or 4g93.. im sure that u will be sad all the day...
Yong_5290
Yong_5290
3,637
49
Klang
hotmail.com
yea...satria wit this engine sure the handling characteristic chg totally...due to the front is so heavy n no tail to balance the weight...tat y many who convert to 4g63 also say the handling bcome vr bad and need a good set of suspension...its already a natural thing for fwd tat tend to understeer...sumore tis 6a10 no lsd 1...hailat lo...
