mess up paint job
kenzo
6,000 RPM
Guyz i need ur help, since's u guyz are DIY experts, i mess up my paint job on my gen2 door panel, here's wat i did.
1. i wash the panel and clean it properly and dried it.
2. i then sprayed the coating and left it to dry under the sun for 10 mins
3. then i sprayed the black paint on the door and left it under the sun for 10 mins
4. and i sprayed the coating and dried it under the sun for also 10 mins
5. then sprayed back the black paint and dried it under the sun for 10 mins
6. and another 1 more time coating and under the sun for 10 mins
took me 4 hours and i was happy with the results, but the paint was peeling off abit by bits, and a scracth could see the original colour again,and one more thing is after i sprayed the coating, the paint started to be rougfh, wat should i do?? i used the anchor spray can and the colour code is H2...it's RM18 per can! ur help is much appriciated, thanks guyz!
DarkAccoon
880
432
3,063
honestly, i dun think u washed it enough, or during the drying process after washing, u gotta make sure no dust falls on top
H2.. if not mistaken that is matte black, or also called flat back rite??
what is this coating that u are talking about?
clear coat or something else?
ken yeang, ps. i think he meant the door panels inside the car
ken yeang
6,000 RPM
6,617
1,327
Dark accoon and Kenzo
If Kenzo meant inside panel, then just ignore my post no 4.
ashton
7
how do u guys do ur own paint?i thot theyre supposed to use that sprayer machine to paint?!
FoarGeez
431
6
Koala Loompour
i dunno much bout paint cuz i basically didn learn about it deeply, but if u planning to do it again nex time, i would suggest using a 'Primer' b4 gettin the color on.. this basically acts like a glue n also enchance the color for the final result.
but primer its kinda hard to find a spray can type, most of the shops selling in liquid type bcoz most of car paint shops use airbrush for finer smooth finishing... theres only one brand i know which is 'Matahari' brand..
i did a small diy recently using those.. will post it soon if got d time.. cheers...
imoloq
1,069
25
1,648
Yes what FoarGeez said was right. You need to use a primer 1st before spraying on the actual coats of paint. Last time I was DIYing my grille, I used a primer before the actual coat and it turned out fine. Just remember to follow the instructions on the primer.
Try Ace Hardware. They usually sell this kind of stuff.
pening99
61
use fine grade sand paper to remove the old paint that u have spray to the panel. make sure u sand all the black paint n then wash it with soap wait until it dry n then spray again with only black paint layer by layer until u puas hati
sory im not good with english but im learning
howiechoo
8,000 RPM
8,857
4
Bukit Jalil
i tot there's something to be apply first before spray on plastic? is it gold oil? sorry dunno wa tit call
khguan
4,818
26
Seri Kembangan
fotopic.net
if u do not want to use primer paint for plastic or cant find it.. u can just use the paint for plastic... u can get this kinda paint from ACE Hardware... brand is Krylon... but not cheap oh... around RM30 per can if not mistaken....
vyruzj
190
Primer = Enamel paint??
Guys,
Currently i have a can or enamel which is bought frm Ace hardware. Is this thing similar to primer?
I have tested the enamel spray on a clean surface. The enamel felt sticky when i touch it. Can i use it on plastics?
jswong
209
9
KHGuan,
Yeah, Krylon Fusion sticks damn well on plastics. It's not cheap, but there's absolutely no mistake. It's next to impossible to overspray with Krylon, believe me. Try it once and you'll see it's a great investment. You can be spraying continuously on one single spot, and it won't drip or smudge. Krylon is THAT good.
The enamel thing is not really a primer, but it's good enough as one. I use it as a primer. Not all enamels are created equal. That enamel from Ace has some adhesive for the base or solvent, that's why it's so sticky. The flash-off time is around 15 minutes, but you can still leave your fingerprint if you touch it a little harder. It's within this period that you can spray a thin, even coat of normal acryllic paint over it. Somehow I find that it bonds to the enamel very well. Since the solvents are different, you won't get the thinner-versus-thinner problem as when you spray acryllic on acryllic. So, you won't get bubbles from under the surface, or the black underlayer rising to the top.
It'll stick to just about anything. Even wood. But it drips damn easily, and it also smudges easily because it's sticky. Lay thin, even layers, that'll do the trick.
lanlee
26
paint job
told by somebody that primer can't be mix with other paint with not the same brand. try to use same brand of paint products. 3 type of paint, enamel, lacquer and urethane. all those type of paint can't mix together. to paint a plastic surface, must add flex addative or the paint will be crack(with spraygun). spraying using canspray, a thin layer at a time or the finishing will be rought. always finish with clear coat to get that shining surface.
ok .. here goes.... im having difficulties on my next project here... i have an E-Class 1995 Mercedes. I have researched and asked many people stating that i need to place in a Toyota Supra or Celica engine... what do you guys thinks... how much will that cost? will that effect any of the handling? will it make it even better or worsen...my budjet is aroung 60k.. please help me here...cheers
