Looking For The Parts Urgent for Airtrek
Feb 6, 2013
Negeri Sembilan
Hello all guys here,
I use my airtrek turbo thats having problems with engine light switch on when start the engine, cannot pull of the the paddle..what is the problem actualy..i suspect airflow sensor.
urgent reply from the members.
DeaconFrost
284
159
1,543
You're correct: most PROBABLY the airflow sensor, otherwise known as MAF sensor.
I've changed many times with 2nd hand units: from Mun Lee, AE - depends on luck. Can last 5-6 months before spoiled again. Cost RM400-600. Better get new unit - costs RM1300 from Ah Wah, RM1350 from Jalan Ipoh part shop.
Before change, better clean first with Electronic Contact Cleaner. Can get this from ACE Hardware. If problem still persists - run EvoScan to detect error codes.
Second most probable reason: MAP sensor - located on the intake manifold.
The most problematic thing is, sometimes if you run EvoScan, you'll get a single error code. It says MAP sensor. You change MAP sensor - problem persists. You change MAF sensor - problem goes away. But there were no error code for MAF sensor.
i remembered I did saw a pic that shows a kancil with the 1300cc K3-VET engine. I would like to ask is that really possible? No problem with the JPJ?
So one K3-VET + installation worksmanship is how much? I also need BOV, intercooler, turbo timer, piggyback ecu remap and all this dashboard meter thingie.....
So if we can install the engine, what about the gearbox? can install also? I wondered if it has CVT..... Also I would like to ask if we can strengthen the gearbox and install...
