Any Sifu/Otai here know this cvt can stand maximum hp/torque before this cvt koyak...
in consideration to BOT this cvt but need info on this one 1st...
i think he is more interested in knowing if the CVT gearbox can handle boost sir..The Mitsubishi 4G18 engine is based on the long in tooth 4G92 with upgrades in the EFI system and the adoption of a modern distributor-less ignition system. While this engine is a traditional engine without the fancy Variable Valve Timing and VTEC-type system, it is a robust work horse and is great engine especially if you plan to turbocharge TC it for more power and torque. It can easily handle 0.8bar or 12psi of boost, giving you about 84% increase in power.
