kancil l2s
Nov 20, 2013
Harlo... need some advise...
getting a l2s soon.
1. 2"piping enough?? I plant to change to 2.2" izzit better??
2. std l2s turbo n td04-09/rhf4 how much diff??
3. L2s std turbo is single/2 fin turbine?? Td0409 2 fin??
4. Can std l2s do wastegate n downpipe??
totally new on turbo.. last time used to be na modification.
thx....
4gbanger
4gbanger
Jun 26, 2013
1,958
386
683
Johor/ShahAlam
1. 2" pipe is enough since everything is stock
2. diff in what? if power, td04-09 is very good for street setup since boost kick @ before 4k rpm. rhf4 u need to mod ex housing in order to use.
3. l2s stock turbo single fin. td04-09 twin. rhf4 also twin fin.
4. depends on ur budget. but it wont give u more power. maybe just slight quicker response.
yh4everlim
yh4everlim
42
5
1,508
Selangor
I mean the different inlet diameter airfilter turbo btw std l2s n td0409. Many use tdo409 should be gd response for l2s.. thx anyway..
td04 inlet from air filter and outlet to the intercooler also slightly bigger, hv to find replacement the ori intake and the steel pipe.. there still a way to use back ori air box la.. but normally ppl juz ikat steel mesh or juz chg to open pod
