kancil 850 gear swap to L200 LSD gear box!
JohnSiew
37
Is it possible that swap kancil 850 gear to l200 LSD gear box? so i can hav 850 LSD gear box :)
JohnSiew
37
coz i have upgrade to 882T so try to use long ratio gear box :)
howiechoo
8,000 RPM
8,857
4
Bukit Jalil
how abou7t kancil 660 ori swap with l2 normal gearbox?
howiechoo
8,000 RPM
8,857
4
Bukit Jalil
will there be any different since l2 is turbo and kancil ori is na?
the gerar ratio is the same?
JohnSiew
37
Kancil 850
Gear Ratios
1st 3.5
2nd 2.111
3rd 1.392
4th 0.971
5th 0.794
Reverse 3.538
Final Gear Ratio 4.473
Kancil 660cc
all the same, kecuali final gear >4.722
Mira L200/s
1st gear 3.333
2nd gear 2.111
3rd gear 1.392
4th gear 0.971
5 speed 0.794
Reverse 3.538
Final Drive 5.076
5.333 --> final drive for L210
as u can see whats the different between kancil n l2 :)
howiechoo
8,000 RPM
8,857
4
Bukit Jalil
so if use l2 gearbox will increase fc when on highway lor...erm...but more power..how ler? wan to change or not?
currently use AT, wish to change to Mt, must choose btw ori kancil 5 speed or l2 gb, wat u recommend?
gsrTurbo9166
958
yo bro
better change to l2 since it come wif lsd if u can find 1
lsd gearbox is better than any of the ori gearbox
helo members,
my gf Sony Ericsson juz kena 'rampas' by a motor in front of Setapak Ria Condo..Setapak here juz now..
HP is Sony Erisccon W550i the latest walkman handphone....the casing is white color and it is original set...
juz 4 days old so it look 100% new
IMEI number is 35744200-425312-9
Let me know if anyone found this...thanks
