is this considered clutch is facing a slip problem ?
darrengoh89
222
8
guys ...need some confirmation from you all...driving 1.3 efi satria
intend to rev my car from :
1.1st gear 50kmh
2.2nd gear 80kmh
3.3rd gear 120 kmh
4.4th gear 125 - 130 kmh
5.5th gear ..still maintain 125 - 130 kmh
sometimes when i slowly drive from 1st gear to 2nd gear also will face some slipping problem ...
but not always ...
so from the statement above ...the 5th gear am i facing a a clutch slip probleM ? thats why my top speed cannot go any further ?
darrengoh89
222
8
can someone reply plz ? =/ ....really need help here ..
---------- Post added at 09:44 PM ---------- Previous post was at 07:16 PM ----------
bump..bump..
ftzone
full throttle zone
5,339
141
3,163
Penang, Prai
www.ftzoneracing.com
clutch slipping symptoms are as follows:
1. RPM increase rather fast but not speed (usually under wide open throttle in low gears).
Causes:
1. Smell of metal burning... sumthing like bad egg overcooked.... (this one when you ride your clutch pedal... or there is some oil on the flywheel surface)
2. Weird sound when clutch engage and it would not even move the car anymore... (this one when your disc totally botak already)
3. Flywheel and or disc contaminated with oil/grease.
the only way to really know if your clutch has really worn out.. is to visually inspect it by removing the gearbox. clutch don't last forever, so a replacement is recommended after 50,000kms or so... or refer to your vehicles service manual.
darrengoh89
222
8
i see ..thx for the advise ...will change it immediately ..i think mine is running more than 70k mileage =X ...and another i need to know ..how come my 4th gear to 5th gear ..which i stated above ...4th gear rev till 120 ..then engage it to 5th gear ...the speed still maintain =.= ....or maybe can go further up around 125 or 130 ? ..if i go with 5th gear from 90kmh ....120kmh already stoped there ...=.= press maximum also cannot really go more ...whats the problem actually lol ?
Hello Friends
How to get waja Auto Flip Side Mirror with LED Signal?
If you have info, please inform me..
Regards
