isnt that kinda low? A friend told me this was about RM6k on google. wowI upgraded my garage with QuickJacks. This car lift system is awesome.
The top of the line model BL-7000SLX which is capable to lift SUVs and pickup trunks cost RM7000. The mid range model BL-5000SLX is RM6500. Since it is RM500 difference worthwhile to go with the top of the line model. But I will caution that the top of the line model is about 8kg heavier.arite... how much did this cost!
this is cool
I think you are referring to the lift height. That is actually very good for a portable lift system. More than enough space to do most of the work required to be under the car.isnt that kinda low? A friend told me this was about RM6k on google. wow
It has actually built in jack stands. Basically a solid metal bar that holds the jacking frames in an upright position. Therefore it does not rely on hydraulic to pressure keep the jacks suspended.I would suggest to put additional jackstand or spare wheel as a backup in any case the liftjack fails/ fall down. just a safety measure
If u see it properly, they are built with safety mechanism. Just like 2 post lift.I would suggest to put additional jackstand or spare wheel as a backup in any case the liftjack fails/ fall down. just a safety measure
okok. just to be extra safe. looks coolIt has actually built in jack stands. Basically a solid metal bar that holds the jacking frames in an upright position. Therefore it does not rely on hydraulic to pressure keep the jacks suspended.
Looking back at the video, the jack looks slightly slanting, not fully upright?It has actually built in jack stands. Basically a solid metal bar that holds the jacking frames in an upright position. Therefore it does not rely on hydraulic to pressure keep the jacks suspended.
The final position with the mechanical lock engaged is not straight upright. There is about maybe half an inch more to go from the locking position.Looking back at the video, the jack looks slightly slanting, not fully upright?
Price I feel is reasonable because there is no other options in the market that gives this portability. My unit runs on 12V so any car battery can power it which makes it so portable. Just load it on a pick up truck and lift any vehicles anywhere. Not only it is lifts higher than conventional jack stands but a level safer than conventional jack stands.Other than its portable, quite the hefty price isn't it, my problem is the height. Add a few more k can get 2 post lift dy but can't simply install everywhere la.
If DIY at home, then 2 post lift loh. This is portable so can do elsewhere.......lolOther than its portable, quite the hefty price isn't it, my problem is the height. Add a few more k can get 2 post lift dy but can't simply install everywhere la.
Even more portable......lolMy low profile hydraulic jack and 4 jack stands quite portable.
I actually thought of that. The problem with two post lift the floor needs to be concrete of a certain thickness which my garage don’t have unfortunately. I actually prefer two post lift but my place does not allow it haha.If DIY at home, then 2 post lift loh. This is portable so can do elsewhere.......lol
AHA...sorry guys but I was out busy racing.
I happy that my top VIOS thread actually registered 70 pages worth of good stuff!
Anyways, I convoyed to ulu Yam last yesterday, met a few guys in ulu yam.
2 RX7s and 1 S15.
They were quite fast but haha...thanks god for my GT wing and 17inch sport rims.
They're...
