Not the new Sylphy, G11 model. Meaning pre-facelift and 2.0L
Swapped out 17" rims Did a complete full service on all oils and spark plugs, DIY of course. Freaking idiotic design. To remove spark plugs I need to drain coolant, remove intake manifold and throttle body and all intake plastic bits. !@)#(!)&%@(#*!(&%@#()$*!
The CVT isn't the smooth ass CVT that you'd be expecting. When driving around (in normal mode) aggressively you can feel the torque pull when flooring it. In sports mode the engine is more revvy and gear changes are more aggressive. Quite torquey engine.
But because of the leather seats and overall weight of the car, no butt cheek clenching cornering cause it's quite comfy. The interesting thing is I can do the same type of cornering speeds as my Wira with all the bars and suspension mods. I haven't quite dared to push the Sylphy yet, haven't quite sorted out the brakes yet. Waiting to get the 4-pots installed.
Exciting? Not really. The sheer weight of the car kinda dulls all sensations from the road and engine noise is almost non-existent. Driving at 160km/h feels like 110km/h in my Wira.
Do I like it? Not really. But can't complain la. It's torquey, comfortable, goddam spacious and quiet.
It's goddam boring. I've almost dozed off a few times driving it. Aftermarket support for the car is almost non-existent too.
Shares parts with Livina and Latio (Says a lot about the excitement of the car) and interestingly shares the same rotors as the Wira 1.6. Dammit.. my Wira had bigger brakes than this car.
Mixed feelings overall. Comfortable and surprisingly handles well with stock suspension and all. Boring because it's lifeless. EPS, quiet cabin and almost no road feel. Basically the plus points is the negative points la.
Oh and gb goes into 'limp' mode if I overheat it. Like driving 160km/h for more than 20 minutes, it'll cut out the power and limit it to 90km/h until the GB cools down. I'm researching ATF cooler alternatives as the way it's designed, it's sort of impossible to install an aftermarket standard ATF cooler.
Lastly... I'm seriously looking forward to pitting this car against SupraFans Altis/Mira in that drag race I'm trying to arrange.
---------- Post added at 10:56 AM ---------- 6 hour anti-bump limit - Previous post was at 10:43 AM ----------
What drone? I didn't hear any drone at all.
and 110km/h is 2k rpm so I rarely drive 3k rpm. But I don't recall any droning noise la.
