Gap on a Stearing
CrankShaft
153
USA
Guys,
What could be the problem if there is a gap when u turn your stearing when u turn there slightly a gap before it grips your tyre?
trex92
756
5,018
dude, not sure wat u mean but all cars has got a certain amount of freeplay on the steering (about 2cm off centre). Meaning, if u put the steering in centre position, u have to move the steering more than 2cm before the wheel would turn.
CrankShaft
153
USA
is that normal? ...but i think mine is too much gap what could be the problem?
tks
559
28
3,028
USJ
uneven tyre wear, cuz your alignment can never be 100% correct. when u drive your wheels will be constantly moving left <--> right, u can feel it la, you'll be constantly correcting your steering even while driving on a straight road.
common cause? rack end/ball head/tie rod, or whatever u call it...heheh! different place u go ppl call it differently. u can check by jacking up the front of your car one side at a time, and rocking your wheels from side to side. from there u can see where the problem is.
cheers!
mustexus
21
hye guys,
i just wanna share my xperience with this problem. i have the same problem after done on wheel balancing. firstly, the steering will have more freeplay. eventhough i go to do an allignment, its still doesnt fix the problem. then, i ve to changed the steering rack and problem fixed. this kind of problem is actually coming from the centre of rack. mechanics prefer to change the whole rack rather then used the old one.
CrankShaft
153
USA
mustexus said:
hye guys,
any idea how much will it cost?
skyline2778
132
Sban
hi,
i m facing the same thing also....how much would it cost fix this thing.....ie:if steering rack,how much....if bush,how much.Tq guys.... :biggrin:
i own a wira 1.6 (m) millennium edition my car shake tedious when idle with air cond on until i can hear my dash board sound, when i press some oil (pedal) the car go back to normal.. for your information my car rpm will drop to around 600 - 700 when air cond on and start shake if the rpm to around 1100 the car back to normal....
my question is... is it normal for my car? can i set my car idle rpm to 1100 so the car won't shake so much...??
