Greetings Sifus,
I hope to seek some advice.
As I have posted before on 4G63T Engine Block. Just to inform all that my car is almost done but I have a query.
My engine had been started and now I noticed that my Banana Manifold glows red in a short while. Any particular reason. It is the normal steel type and not the stainless steel. I have wrapped is with Thermal Wrap. Just after one round of testing - around the factory lot it's glwoing red. Even got flames !
Secondly I have fuel supply problem ! I suppose. The boost is at 0.7 bar and I have a SARD fuel pressure regulator. It is set at 3 bar. I am unable to hit 4k RPM because there seems to be fuel lag. WHen I rev the idling also does not come back to normal. Does the wastegate open when we ram at still ? Or is it only supposed to open when you are on the move ?
I need some professional advice on what are the areas I need to check. Plugs are new NGK Iriway 8. All injectors are original.
Thanks in advance people !
