front wheel caster lari....
sunnyboy
439
can anyone guide me where to fix caster....
after i did my alignment, the mech told me castor run off already....but he can he cannot fix it...hav to find mudguard fellow....is it true?
any comment?
jasonlel
440
Johor Bahru
Sunnyboy,
Caster can be adjusted but to a very minimal adjustment can be made, unless you want to pull back your caster that's another story.
Before doing anything, why not you tell us what's your caster reading? Factory caster measurement is about LEFT/RIGHT 2.33 deg. Normally the caster measurement for LEFT side is higher than RIGHT side due to Malaysia road are design tilt to the left.
Regards,
Jason LEL
*Not may ppl knows how to adjust caster
vestax
1,573
7
Damansara Heigh
www.fivio.com
my caster also lari , cause i went in a darn big pot hole , so all tyre shop ask me to go to mudguard shop to pullback the caster . now okay aready i assume .. cost me RM 30 to pump back the caster ..
sunnyboy
439
Originally posted by jasonlel@Jan 25 2004, 02:30 AM
Sunnyboy,
Regards,
Jason LEL
aiya....forget to take down the caster figure when doing alignment......but the tyre fellow said lari already, and the machine reading also showing that....
i think the caster run off due to accident.....so it's a pull back procedure
any mudguard shop to recommend? since not many know how to adjust....
Vlad
210
try checking your lower arm bar , sometimes its the lower arm not the caster..
mine was also unaligned then soem ppl told me need to go mudguard lou fix , didnt
feel quite comfortable , then i went to this shop in tmn mayang that fella told me its just the lower arm bar... changed the whole damn thing caster back to normal position. haha
waikitfire
226
CHERAS
yr enjin too powerful liao .... :) nvm leh,
:lol: :lol: :lol:
vestax
1,573
7
Damansara Heigh
www.fivio.com
i buta buta mention i went in a big big pot hole , actually its not a pothole , it was a 4 meter deep hole .. half of the car went it , stupid road works didn't put any warning , and that time was raining .
waikit my car not strong as yours , boost 1.8 bar .. and i don't laugh at peoples car :lol:
my car which engine is mitsubishi 4G91
at 90km/h the RPM already 3K
which i think is quite high
is it possible to change my 5th gear to make 3K rpm at 100-110km/h???
because i travel quite alot at high way therefore can help me to save some fuel also
where got forman can do it??
roughly how much will it be??
