front disc have scratch
spoon civic
403
36
528
terengganu
dear members..pls help me..what is the problem for my civic fornt disc brake?the front disc left side have scratch..i already change to another caliper complete with another nice disc..but the problem still same...my mechanic said that was brake masterpump problem..is that true?pls help me....
lot
77
kl
scratch or groves ?
just get it resurfaced. but check to see if the disc is warped (bend). why did you change the caliper ???
something is scratching it.....inspect carefully and look for a second opinion. master pump or brake pump regulates the pressure on the pistons in the caliper.
pls think rationally. The best mechanics I know are rational people.
ditto on the brake pad assembly.
spoon civic
403
36
528
terengganu
scratch or groves ?
brake pad are still thick and change with new caliper ,changing because i think maybe caliper piston stuck or etc,but master pump problem maybe the cause....:hmmmm:
kayour
326
41
caliper and disc changed??
and happen again??
maybe ur mechanics rite...try to service master pump
There are 3 types of LSD....
- 1 way
- 1.5 way
- 2 way
Currently Im using 1 way LSD only, launching the car from stand still is perfect. No more wheel spin no matter how much I floor the pedal. But 2nd gears tends to wheel spin a little (too much tork on a 2.2 engine). Overall cornering is superb can feel the grip of the tyres very well. While sliding the car, counter steering seems more responsive and easier to correct the slide.
