Yah, maybe be next time should try combo V12E2/S1E2 or F1D5/F1A5. :-)Wah! directional mixed with asymmetric......like Pirelli P Zero Corsa System.......hahhaha
bossWhy not just use 245/40/18? Much cheaper and common size, closer to the front 225/45/18 and better fit for 8.5j rims on your F30.
You got PM boss. I think rear got better traction is safer. They say new tyres go rear.2 front 1 brand, 2 rear another brand is okay. I use many times like this when changing brands.
I check a few shops, Falken some at 800, 730 cheapest. One shop no Falken say PS4 810, that is why I let you know......lol
I know diameter wise it's slightly smaller but width is closer so less understeering tendency. Anyway 8.5j also better match fitment with 245. I'm also now using 225/45/18 & 245/40/18.boss
https://tiresize.com/comparison/
225/45 R18 fronts
255/40 R18 rears
are identical in diameter
245/40 R18 will be 7mm less for the rear...
FR setup naturally oversteers right? I kinda like the way my car handles now.. a bit of throttle it will still oversteer..I know diameter wise it's slightly smaller but width is closer so less understeering tendency. Anyway 8.5j also better match fitment with 245. I'm also now using 225/45/18 & 245/40/18.
Replied to you already. New tyres rear, yours RWD even better, but yours staggered so cannot change......lolboss
225/45 R18 fronts
255/40 R18 rears
Hankook S1E3 already, by then maybe V12E3 also......hhahahhahhaaYah, maybe be next time should try combo V12E2/S1E2 or F1D5/F1A5. :-)
Ah ok in that case then stay with same tire sizes.FR setup naturally oversteers right? I kinda like the way my car handles now.. a bit of throttle it will still oversteer..
can save rm10 for motorcycle EO also ok. motor also cannot rempit already. for taman useOh really? Still why buy copy tires? It's already cheap anyway right?
Yes, ZE-914 Eco Run is Mid range touring tyres. FK series are UHP categoryIsn't there a ZE-914 already? Yes 912 was quite bad, my friend one was having issue back then.
How does one hit potholes with rim denting impact without realising it? Tummy upset again?Well no more sweet rubber smell. Run in well. Tyres are doing well, no uneven wear, I must have hit some pothole somewhere both front and rear right rims bent... had to repair, lucky tires are fine.
I think I forgot about it after the impact. Brought car to tyre shop then they told me.How does one hit potholes with rim denting impact without realising it? Tummy upset again?
Pulling your leg, Bro. Thanks for the reviewI think I forgot about it after the impact. Brought car to tyre shop then they told me.
Exactly, I used to use Yoko S-Drives. Friend say PS2 better, I say I know but I don't drive to PS2 max standard, where S-Drive can handle about 80% of PS2 but cost almost half only during that time.......Well no more sweet rubber smell. Run in well. Tyres are doing well, no uneven wear, I must have hit some pothole somewhere both front and rear right rims bent... had to repair, lucky tires are fine.
Consistent, no complaints and I am gradually pushing them more in the corners.
I think at the price, I will definitely give it 5/5 rating. Don’t compare with PS4 please, if you’re willing to pay ~40% more just buy the PS4.
Thread starter | Similar threads | Forum | Replies | Date |
P | Continental MC6 vs Falken FK510 vs Continental ExtremeContactSport | Wheel And Tyre | 52 | |
Falken ZE914 v Kumho HS51 or vs other assy tyre | Wheel And Tyre | 8 | |
New Tyre from Falken - Falken FK510 | Wheel And Tyre | 0 | |
Falken New Tyres - ZE-950 | Wheel And Tyre | 16 | |
D | How's falken azenis Pt-722? | Wheel And Tyre | 3 |
