extractor + exhaust
crazykatak
776
48
Subang Jaya
stock headers are 4-1 into a catalytic converter.
an AT car would benefit from 4-2-1 header because of the linear power gains from low to mid and abit of high rpm.
where the 4-1 power is from mid to high rpm range.
so, a good setup should not make u sweat when cruising on the highway or moving from traffic light stops.
it's wiser to put the power where you want it and not somewhere difficult to reach, that way you could save fuel and prevent premature engine damage ( due to keeping rpm range high up there )
nyantong
192
50
Decat-ing your stock exhaust will improve your power. It would be like having a very short 4-1 manifold. However, as you did not specify just what car you are driving, hard to say whether removing the cat would cause an MIL for the engine to light up. Most likely the oxygen sensor would indicate lean mixture in the exhaust. If you have more budget, I'd suggest changing the entire extractor to either a 4-2-1 or 4-1. Having used both, I'd say they both improve power. If you love revving the engine as I do, a 4-1 is better and the torque peaks at high RPMs. If however you wish to tune your car for better pick up, go with a 4-2-1. Either way, you won't regret.
escksu
145
28
528
Singapore
Btw, if you are keen, the Works Eng exhaust is pretty decent. I am using it right now. Not too expensive too for a full set.
Similar threads   Forum
Car Detailing Forums
Looking For
Similar Threads
hi guys, i am wondering that whether carburator can bolt on turbo or not ?
anybody try this b4?pls share.
pls give some info for this kind of mod. thanks guys .
