Essential RX maintenance
reartyre
145
I Think We Need To Have A Workshop Day La ..... It Just Kills Me To Visualize All The Thing That Needs To Be Done ....
13btt
301
13
Sydney, AUS
www.reclub.com.my
My understanding of coolant as follows:
The coolant (green or red stuff) contains ethylene glycol which is primary used to raise the boiling point of water above 100 degree celsius and also to stop the water & coolant mixture from freezing in sub 0 temps (not needed as we always stinking hot in KL!). In addition to this it helps to lubricate the water pumps seals (very important) and prevent corrosion of aluminium & iron engine internals - you'll notice it is a little oily.
However, ethylene glycol (coolant) also reduces the heat absorption of water and thus reduces its ability to transfer heat from the engine to the radiator therefore the more coolant you have the less heat transfer too = higher water & engine temps.
The water wetter is to reduce localised boiling by reducing bubbles in the water and in turn increases water to metal contact for better heat transfer. Air you should remember from chemistry/physics is a very good insulator (i.e. doesn't conduct heat very well).
Hence, if you put the above understanding into practice you should keep coolant mixture low ie less than 30% IMO for optimal effect i.e. good heat transfer of water and slight increase in boiling point of water.
Also as far as radiator caps go they are designed to raise the pressure of the cooling system as a higher pressure equals higher boiling point of water too. BUT too high a pressure (i.e. 1,3bar) stresses the o-rings in your engine leading to premature failure = full rebuild required.
Hence IMO use 0.9bar to be safe or max 1.1bar if you need a little higher boiling point of the water.
I trust the above explains the whole thingee and removes any confusion?!?!
Alchemis
1,416
47
1,648
i got myself a SARD alluminum AST... it comes with a 1.3 BAR cap... guess i need to put in another cap..... wasted..... the SARD 1.3 BAR cap is EXPENSIVE if purchased seperately.....
reartyre
145
13btt said:
Standard for FD to run between 82 and 110 degrees but much safer to run under 100 degrees most of the time. These temps are with the oem 82 thermostat in place.
hey mr gwai loh ! ... when can u help me fix my apex'i water temp ... been waiting since the third day i bought my car man !
thanks man
reartyre
145
digital .... i think you've seen it man ... fix a time and i'll gladly come phat!
thanks man
khbeh34
67
Realiable????
To every expert at here....Is that the RX-8 Rotary engine Realiable???? Heard the machanic said this engine always 'eat' oil---> afterthat have to rebuild or change engine? I'm planning to buy a RX-8 manual with Mazdaspeed bodykit.... suddenly heard the machanic say like that, feel very shock dunno should i buy or not....
Thanks for help to answer my question.... Newbie here...
13btt
301
13
Sydney, AUS
www.reclub.com.my
Can't trust mechanics in what they say when talking about rotary engine here - they don't have the skill / lack of knowledge with them so they say they (RE) are crap / unreliable. To them it is better to say engine no good then as that way they save face / maintain your confidence in them as mechanics lah.
Isn't it typical for one mechanic to run down another mechanic just to get your business...? So how can you trust their objectivity and provide an unbiased opinion??
Simple answer really - look at rotary's history overseas say in USA and Australia and that should answer your Q. Local knowlege amongst mechanics in KL is limited hence the bad publicity / reputation. See "rotary engine no good lah" posting for all your answers.
khbeh34
67
Sir, if i didt do any mod in RX-8 is it oso a daily use car? RX-8 can drive in highway? will it overheat?
thanks for answering me.... i really look like idiot coz i ask the dump dump question...
jasonlel
440
Johor Bahru
No question is dump, but . . . :emoticon_U:
khbeh34 said:
Sir, if i didt do any mod in RX-8 is it oso a daily use car? RX-8 can drive in highway? will it overheat? by the way if i wanna modified at the performance parts which will u recomend me?
13btt
301
13
Sydney, AUS
www.reclub.com.my
No it won't overheat and yes of course can use as daily driver. Mazda wouldn't design a car that isn't reliable especially the RX-8!
khbeh34
67
good news.... i'm ordering a RX-8 wit Mazdaspeed bodykit plus manual version... Wish me luck.....
phat7
2,122
62
well done. do join us when you come to kl
quixeric
127
welcome to the gang, hey alchemis how much did u purchase the SARD AST and whre ya get it. im looking for 1 now, think i will use back the 0.9 caps
Alchemis
1,416
47
1,648
i got it from ah choy.... around 500...
comes with a 1.3 BAR cap. useless. i swapped back with the 0.9 BAR
his place also have a taiwan made AST... that cost almost half the price only.. but serve the same purpose.
i've changed my power steering fluid
the prob is the day i've change my power steering fluid, my steering runs smooth i the steering is very light
but after 1 week, my steering return to the previous condition that the steering is hard
what is the prob?hw can i do with it
i've asked my friend and he says got air inside the power steering hose and he teach me to repair it. he teach me to turn my steering over and over again when the engine is on. i've tried but nthng happens
