enjin kia spectra vs enjin toyota black top
Dec 21, 2011
Penang
kepada otai2 enjin tolong bagi tahu kepada saya-yang manakah penggunaan minyak yang tinggi antara kia spectra vs toyota black top enjin.?maintenance plak yang mana lebih tinggi..?
DanzEterna
DanzEterna
15,914
3,371
PJ
www.primeperdanaclub.com
bro, pls use english.
anyways, back to yr question, of course toyota black top has higher FC & maintanance should be slightly higher as its a tuned engine, spectra is stock std.
Veloc
Veloc
3,234
991
Sabah
Err... Kia Spectra? What year and what displacement? Do they only have 1 engine, the 1.6 L one?
If the Kia is 2.0 L then I would say the Kia engine drinks slightly more la. Because BT is quite economical really if you leave it standard. Most of my friends get around 60 km for RM10 RON 95, town driving.
Supra_Fanatics
Beyond 20,000 RPM!
Supra_Fanatics
Beyond 20,000 RPM!
20,674
3,998
Ya, only 1.6 for spectra, My boss is driving one and he said it consumes petrol
like drinking water...never ever buy spectra as I was told LOL!
If were to compare I'm not sure which since I have not really driven spectra
before but only SEG with 4AGE once, so far, my friend never complaint
Blacktop makan minyak. Might be still better than Kia Spectra I guess...:hmmmm:
jeheyr
jeheyr
834
19
5,018
Ampang Jaya
community.webshots.com
On my opinion, 1.6 spectra & blacktop toyota are two different category of engine... Blacktop slightly more to high performance engine... but for the fuel comsumption, its depends on your own feet and engine setup.... correct me if im wrong... ; )
Shahardi
Penang
thanks about ur opinion..cause i want change engine kia spectra 1.6,year 2003 to toyota black top..i want to know its fuel & maintenance & cost to change it.
D7zul
D7zul
2,697
848
713
Shah Alam
Blacktop the best.. haha..
miss my blacktop :bawling:
i'll get a blacktop as soon as my pocket permits :biggrin:
muzhaffar
muzhaffar
251
41
not know about spectra FC
but own a blacktop before...FC depend on your right foot
if you drive 80-90 only, rev under 4k rpm, the fuel consumption is astonishing..
i manage to go back to kota bharu kelantan from gombak for only rm50 petrol(petrol is around rm1.80/l)
but i rarely exceed 90kmh that time
however, if you manage to stick the accelerator pedal to the floor all the way, your fuel warning will light up when you approaching gua musang..also before this, i fill full tank at gombak, go to puchong at normal speed and from puchong i floor all the way to ipoh while tailgating 325 coupe on plus highway, the fuel is almost empty at tapah rnr..so basically, it really depend on your right foot at all..
for the maintenance, just need to maintain engine oil..need to choose the correct engine oil or else you'll find that the engine oil disappear from your engine..and for the parts, reliability etc, dont worry..it really tough engine..(at least on my case)..never brake down..just once the clutch broke up because i always slam it when changing gear..
but 1 thing you need to bear in mind..this engine is designed to run on RON100.so, it is advisable to use RON 97 since ron 100 is not available in malaysia..even using ron97 also sometimes cause knocking..even worse if using ron95..lot of power lost can be felt if using ron95..
