drive shaft problem or CV problem?
weikhee86
423
can anyone help me? i need opinion here..everytime i turn the steering wheel and press the accelerator pedal, there is this tak tak tak....sound coming but no vibration of any sort...if the drive shaft have problem is it possible to repair or replace with a new one? or is there problem with the CV joint?
weikhee86
423
thanks guys...btw, anyone knows how much it would cost to replace CV joint? not cheap rite? btw, i drive a proton
ler
175
KL/SEL
pls oso check your adsober rubber top mounting..maybe it tears ..it happen to me be4...
johnsmith
224
not sure if proton sell the cv joint itself, but if they do, maybe RM100 or so...or somewhere near there. that is for proton saga, wira range but if perdana, i don't think it is around there. maybe double? the price above is for one side only. you might need to change both sides (L/R). if centre giving sound (not likely), you might need to change the centre.
if they don't sell the cv itself, you need to buy the whole shaft which will be costly. nearly RM1k for both sides.
good luck:regular_smile:
johnsmith
224
xtorm said:
hmm....how abt 'tok' sound when ever i turn my steering, it only happen after my car is park for some times, bcos of the spring?
spring normally don't give that sound. i guess it is the brake pad is gripping the rotor. it could be your rotor wrap or disk pad uneven wear caused the brake pads gripping the rotor harder than normal and this cause tok sound when you park your car too long.
First we must know what is HID?
HID, High Intensity Discharge, refers to lighting technology that relies on an electrical charge to ignite xenon gas in a sealed bulb, similar to the lightning phenomenon in the sky. HID lighting does not have a filament but instead creates light by igniting an electrical discharge between two electrodes in an air tight tiny quartz capsule filled with xenon gas. HID lighting are also called Xenon lighting, referring to the gas inside the bulb.
HID stands...
