DIY modified Short Shifter for Wira/Satria/Putra
khguan
4,818
26
Seri Kembangan
fotopic.net
There are many types of short shifter in the market nowadays.. n most of them cost around rm140 and above... some even have adjustable pivot points.
I have been using an aftermarket short shifter for a period of time... i have compared the physical thing with the original one sided by side, the difference is the raised pivot point that makes the shift throw shorter...
so i checked on the internet for other sources of short shifters in the internet n i have gather enough information to mod my own original shifter... wanto DIY mah..
so heres my version of short shifter... it cost me RM30 to do all de cutting n welding on the shifter..
click here : http://khguan.fotopic.net/c639577.html
youmolo
208
Subang Perdana
www.tzywen.com
cool short shifter mod :)
anyone thinking of doing DIY sequential gear shifting (like f1 and rally cars)? could be done using powerful servos or solenoids and some electronics. just a thought...
joe_jawa
23
port dickson
how many cm did u add for those???i think i wanted to do it myself....teach us sifu!!!!
khguan
4,818
26
Seri Kembangan
fotopic.net
youmolo,
sequential?? too messy to do it la... not easy...
joe,
look carefully in de pic... bottom parts plus 1", upper part minus 1.5"
frcgrey
196
selangor
hi khguan,
i had already visit your web...
can i ask you that the modified L.E.D bulb with normal light bulb stand.know what i mean...?
if yes,where are you fix it??fog lamp or.....?
hear you soon.... :confused:
khguan
4,818
26
Seri Kembangan
fotopic.net
i use them at de side bumper light there... looks nice...
but one piece already burnt... looks like de voltage is not fully matching...
simefly
449
You can also try to use it as the reverse light.... looks nice too man....
khguan: maybe you should add another LED to cope with the voltage fluctuations
simefly
449
Oh yeah... forgot to mention... NICE DIY man but where do you go to do the drilling and soldering???
khguan
4,818
26
Seri Kembangan
fotopic.net
simefly,
yeah.. i have tot of adding another LED in de pairs of 4 making it 10 LED bulb... i also tot of using de same config but add in a LM7812 regulator IC... anyway dat DIY put aside 1st lar...
huh?? driling?? no drilling involve ah... just cutting n welding... done at an engineering firm...
simefly
449
oh hehehe ...sorry wrong use of words... i was thinking of something else for a while...
it suppose to be cutting and welding.... my bad..
I do not have my tools readily available with me at this point in time... but as soon as i get back by CNY, then i will start LED-ing my whole car - including the signal lights and small lights hehehe... Then planning to add-in HID for the finish and most expensive effect.
Hehehe
howiechoo
8,000 RPM
8,857
4
Bukit Jalil
khguan, ur led bulb fail because car work on 12-14.4...not really 12..so ur led will be stressed..
Hi all..
I've got problem with my car a/c. suddenly feel did not cold. And in this video this is what my compressor behavior. Is it normal? When I open throttle a bit, the compressor cut off.
air con compressor cut off - YouTube
