DIY Honda ECU Repairs- P30 P08 P27
E-Tech
1,115
256
3,183
Johor
Iceman...
If still still problem, send me pictures of
The ecu..
Any error codes?
iceman401
141
unable to detect codes now. not sure what had happened. once jumped the socket, the check engine light blink abnormally. not sure what had happen here.
E-Tech
1,115
256
3,183
Johor
???abnormal?
Test on another car and try to get the code.
iceman401
141
bro, i replaced with another ecu. replaced all the caps and ic17.
car can start but now showing code 14 and 20. any idea?
E-Tech
1,115
256
3,183
Johor
Code 14- iacv
Code 20- eld.
14 needs to solve if not idling up and down.
Check the related transistor to iacv.
20 should not be a problem...
iceman401
141
the idling was fluctuating up and down. when the car is cold, start and the rpm was too low ard 500rpm that it dies off all the time. so everytime start up need step on the throttle to give some gas. problem of the iacv solenoid?
E-Tech
1,115
256
3,183
Johor
Iceman...
COnfirm the iacv solenoid with a good unit first to confirm.
Is still cannot maybe got conponent in the ecu burnt.
Tq
iceman401
141
hahaha bro,
not yet check, have to go halfcut shop buy one iacv 1st lo..
replaced the caps and ic17 ord..
ryand
47
1,508
hello
i need help my P27 ecu sometimes work but sometimes steady cel i do not hear the fuel pump engage.
i tried using another p27 ecu it works fine. test the faulty p27 in other cars same problem sometimes is work sometimes steady cel.
changed all the caps.still same problem.
help pls.
ryand
47
1,508
IC17 ? what is the function? part number?
I found some related thread they say its the QM3 STA412A
can you verify?
many thanks
E-Tech
1,115
256
3,183
Johor
Ha ha ha....
Ur symptom Cel take long time to off?
If Cel off can start. If on cannot start?
Yes-->ic17.
STA have burn mark?
ryand
47
1,508
it usually starts when you plug in the ecu cell comes of instantly and i hear the relat but turn it off and on again sometimes it still works ok and starts. but sometimes cell wont come off and no relay sound.
change all the caps.
---------- Post added at 11:33 PM ---------- 6 hour anti-bump limit - Previous post was at 11:30 PM ----------
no burns on sta412A
IC17 looks good also
---------- Post added at 11:41 PM ---------- 6 hour anti-bump limit - Previous post was at 11:33 PM ----------
do you have the model or part number for the IC17
E-Tech
1,115
256
3,183
Johor
Toshiba TA8903SN...
I have sOme if u wanna buy..:-)
Note tat IC17 can be spoilt without any
DamagE mark...
Anyone know where i can find a car polish & wax centre that i can send my car to do polish & wax ( Kuala Lumpur Area). Thanks.
