DIY Heat Shield for Open Pod
InitialD
1,299
93
Cool! Thanks!
Question.. is it better to put the superleon on the outside rather than the inside or no difference? Is superleon fireproof?
anion
1,083
76
5,148
i guess its better to put the superlon as in the inside as facing the air filter.....coz alu will heat up too....
superlon is not fireproof but it can stand a very high heat temperature.....i tried to use lighter n burn the superlon...but it doesnt catch on fire n burn but it smokes and melts.....
jackchoo
5
no problems....I did mine with .5 mm aluminium sheets. Pretty cheap. made a huge difference on the low end (which sucked after I installed an Apexi Pwer Intake).
Use a cardboard to first do a template, trace it onto a alu sheet and cut with a pair of garden shears. For inner lining I used some industrial rubbet sheets, maybe not necessary. mail me and I can send you my DIY document (too huge to attach over here)
Mines a 200SX S13 CA18DET.
Choon
117
Perak
Hmm... quite good..
i'm new here but i got a suggestion:
wat if we use asbestos, the one we use on our house ceilings.. it's made to insulate heat...
just use a manila card to try the best shape to insulate heat then trace it on the asbestos...
then cut and install... i think it shud be cheaper than using superlon and aluminium...
i plan to do this but stil haven't got open pod..
btw, how much does the Apexi open pod cost? i read from some article in the web and it said it has good filtration and good HP increase...
masvidal
253
Kota Kinabalu
i salute u anion. really nice build up there. i try to make one, but it turn out ridiculous....hahahaha. really difficult lah to make for proton wira, small space and lots of wire......
tleilaxu
464
14
jb
i`ve got a heat shield for sale..bought frm speedworks n was fitted in my satria..letting it go cheap..pm me for details..
i`m using mitsubishi eterna twin turbo 2.0 v6....my turbo boost only 0.4 and my car never modify b4..so what can i do?? i`m newbie and know nothing...pls help..!!
