Customised Radiators
Wild_Seven
79
3,008
Fellow members,
Just wanna ask if there is any good shops that can customised radiators for continental cars?
Thank you in advance.
Cheers
Wild_Seven
79
3,008
Veilsideboyz,
My radiator is new. It is not broken. As to why I asked for customised, it is pretty obvious that the original radiator couldn't cope with the heat generated, especially when it is driven hard on the track.
JinKL,
Thanks, will contact him.
Cheers
celicacultus
41
Aluminium radiator will definitely help. For the tracks, you might want to consider other things like exhaust wrap, coolant, low temp thermostate, oil cooler, venting outside air for your intake, etc.
Wild_Seven
79
3,008
Thanks celicacultus.
The original radiator is already made of aluminium. Have used waterwetter and lower temp thermostat but to no avail especially at Sepang. Only option is to use bigger radiator. Have found one supplier in Australia, PWR which also manufactures oil cooler.
Cheers
To all sifu's, pls advice. Can the aircond system in a 4g93T be used in the 4g93P engine? Are the piping the same? HOw about the electronics to control the aircond? Can all the control on the current proton dashboard compatible with the aircond socket from the 4g93T?
Pls feedback. Thank you.
