Custom vented hood for more cooling ?
Mitevo7
1,456
179
3,163
Dear All,
As some of you may know, i just converted a BMW E46 with 1jz engine, due to i am getting more and more familiar with the new characteristics of the car and i have been pushing it a lot. Now i've noticed, whenever i floor it hard and fast, the water temp will raise a little over the mid mark, upon slowing down, it will return to below middle. Have asked the mechanic that did the conversion, he said its very normal because its a turbo engine, when push hard thus will hot a little, plus recently the weather is crazily hot.
With skepticism, asked another mechanic which i never dealt with before, he mentioned the samething as he's thought its quite normal, however, he gave some suggestion on venting the hood and side fender for hot air to exit faster.
Therefore here comes this discussion, how effective is it to vent my car's body parts, or i should just get a low temperature thermostat and call it a day ?
Thanks,
Ken
gunnerzz
Jul 3, 2014
2,109
695
713
38
Melaka
Maybe...more hot air escapes thru the vent rather than recirculating back to the front of the radiator. But vent will help most when the vehicle is moving. During stationary it all depends on the radiator fan and the air temp the radiator is getting.
I rather seal the radiator area to prevent any chance of hot air from the engine bay getting recirculated to the front of the radiator.Very difficult to do but rewarding. I did that on the Kenari and aircond is much better too.
Mitevo7
1,456
179
3,163
My issue is when i am driving or racing it hard, the temp will creep a little higher, from what i read, 1JZ normally installed in larger Toyota cars. BMW E46 is not at the same league with Crown, may be that's why the hot air is kinda trapped in the engine bay.
Can you share some picture how you seal the radiator area ?
Thanks,
Ken
mADmAN
1,840
547
3,213
venting the hood if done properly can reduce the engine bay temperatures via the venturi effect. will minimize radiant heat being soaked up by ur engine components.
however, i would suggest a lower temp fan switch and thermostat. so that the fan will turn on at a lower temperature and cool the water earlier. a fan shroud would probably help as well.... after thats done, u can look into the venting.
  • Like
Reactions: sanekit
Mitevo7
1,456
179
3,163
Dude you foreseen my actual plans, indeed i am getting fan controller and lower temperature thermostat now. I don't want the modified body to attract any unwanted attention from authorities eventhough i am legal. My exhaust note is already quite a police magnet when i drive fast lol.
Thanks,
Ken
Dear All,
Thanks,
Ken
Ho ho ho... this was one of the things I mentioned to you right? The 1JZ runs hot. Uprate the radiator and fan and it's limited by the flow of the engine bay. I had the same problem with my 36 sometime back and my oil temp would touch 110 at time too with the water also reaching 100. I was looking for vents until I went for the old school mechanic way of raising the hood with some washers to test my theory of poor airflow and lo-and-behold, the temperature stabilized and although it still went up during spirited drives, the heating up wouldn't be as drastic. Perhaps you should try raising the hood as a temporary measure.
marsha1l_v6
666
130
543
i just ordered spal last week..else can share shipping cost.
im working on reducing engine bay temp as well. using low temp thermostat..and raised front hood
All turbo cars runs hot, especially when pushed. The turbine will be really hot, and water and oil sent there to cool that part will become very hot and when return to radiator and engine sump respectively, will spike up the temperature, that is why need engine oil cooler too.....
6UE5t
6,000 RPM
6,756
1,300
nah.. get a fan with a higher CFM. More blades doesn't mean anything la.
I think it should. Just compare ceiling fans with 3 vs 5 blades. Replacing the motor with more powerful one of course is even better.
Reading your reply, made me google, then saw this......lol
Fewer Blades Mean Less Drag. Many believe that the more blades your fan has, the cooler it is, but it isn't secret that industrial style and commercial fans usually only have two or three blades. ... When a fan has fewer blades, there is less drag on the motor and it can go faster and move more air more efficiently.
Looks like stronger motor is better.....
  • Like
Reactions: sanekit and Izso
6UE5t
6,000 RPM
6,756
1,300
Makes sense so need to pair with stronger motor as well.
Mitevo7
1,456
179
3,163
We will try with cooler temp and fan controller at lower temp, but that will mean work the fan quite regularly. I might need to look an M3 side fender with stock air vents that can let the hot air escape from the side. It's more stealthy and low profile.
Thanks,
Ken
Mitevo7
1,456
179
3,163
Well said, lots of coolers need to be installed then if i want to drive like i stole it. For now i only able to drive it hard for short period of time before seeing the temperature creeps over mid point.
Thanks,
Ken
Hi
I am from UK but I live in Thailand but I will be in KL next week, I have one free day on Tuesday. My hotel is near KL Sentral station.
I have been to KL before and seen the normal stuff for tourist, but I am a petrol head, is there anything interesting to see in central KL, maybe buy some accessories for my car (but not big because I will fly back to Thailand) or any place to look at cool modified cars on the KL scene?
I drive a Lancer so the Malaysian scene is interesting for...
