coilovers
NJK
NJK
Jul 29, 2018
8
ah ok. if like that u will need the knuckle and the driveshaft. did some search on other forums, evo driveshaft is a bit larger than airtrek so not direct pnp on the knuckle. if u just swap the calipers, just like u said, you will need brackets. but cheapest option is caliper and brackets.
Ok, thanks for the info bro!
  • Like
Reactions: sanekit
4gbanger
4gbanger
Jun 26, 2013
1,958
385
683
Johor/ShahAlam
u gonna need the evo front driveshaft and steering rack in order to install evo knuckle. everything else can use back airtrek parts. for the rear brembo, need to mod abit at hole to install at airtrek knuckle. hope this helps.
  • Like
Reactions: sanekit and NJK
NJK
NJK
Jul 29, 2018
8
Thanks bro! decided to go with bracket. installing soon.
  • Like
Reactions: sanekit
