Cleaning car seat belts
cbsteh
310
144
543
Kazakhstan
www.christopherteh.com
It appears cleaning car seat belts requires a different methodology than just spray APC and wipe.
May I know what is an effective and quick method to thoroughly clean the belts so they appear like new?
Some say to completely stretch out the belt, gently close the door so the door holds the pulled out belt, spray APC, leave it to soak, then power wash the belt.
KrisMas
434
175
1,543
I cleaned them once with an apc & a shoe brush....worked well. Wiped/rinsed afterwards with a damp cloth...of course...
kc2
1,354
1,410
thedetailers.blogspot.com
Any mild shampoo and less corrosive substance will do
Hair body shampoo is great
As it is strap to your body
Unless you have grease or windscreen glue like mine at the rubber trim and stain
Therefore I use safe APC - alien power clean and free of casinogen / cancer causing agent
Proton Wira 1.8 SOHC turbo Automatic
Spec
1.4G93 SOHC Engine
2.OEM Pistons
3.Cleaning Head and Polish
4. 510cc injector
5.Walbro Fuel pump
6.Turbo TD05 Evo 2
7.GSR Turbo Manifold
8.Microtech LT4 Fuel controller
9.RED Line Racing Lubrican
10.RED Line ATF Racing
11.No Intercooler
12.Blizz Air Filter
Tuning done on the Dyno At Mellinium Motorsport Sunway,and make it the
164 whp 210ft torque at 0.9 bar boost.The oem auto trans still can support for 1bar boost.
The engine fully rebuild...
