Can we take out our thermostat from our car engine
wsonny
467
5,018
Ampang
Can we take out our thermostat from our car engine, someone said is better to take it out so the car engine will run cooler. Wat is the pro n con?
tofu_manic
1,342
91
From an article, nicely explained:
"A car thermostat has two separate but interrelated functions:
1. To bring the engine up to optimum operating temperature as quickly as possible; and
2. To maintain the engine at optimum operating temperature thereafter.
Discussion
An internal combustion engine operates best at high temperature, with the coolant in the cooling system typically above 80°C - 85 °C (176°F - 185 °F). Wear on the moving parts is reduced and thermal efficiency is increased. Lower temperatures result in increased fuel consumption and reduced engine life. Higher temperatures result in overheating with the danger of premature combustion of the fuel air mixture, also know as detonation or knocking, and damage to engine components.
To ensure that the engine reaches optimum operating temperature as quickly as possible, the thermostat restricts the flow of water from the engine to the radiator to virtually zero (a small flow is required so that the thermostat experiences changes to the water temperature as the engine warms up) until the engine reaches optimum temperature. The thermostat then opens up to allow coolant to flow through the radiator to prevent the temperature rising higher.
Once at optimum temperature, the thermostat controls the flow of coolant to the radiator so that the engine continues to operate at optimum temperature. Under peak load conditions, such as labouring slowly up a steep hill whilst heavily laden on a hot day, the thermostat will be approaching fully open because the engine will be producing near to maximum power while the velocity of air flow across the radiator is low. (The velocity of air flow across the radiator has a major effect on its ability to dissipate heat.) Conversely, when cruising fast downhill on a motorway on a cold night on a light throttle, the thermostat will be nearly closed because the engine is producing little power, and the radiator is able to dissipate much more heat than then engine is producing. Allowing too much flow of coolant to the radiator would result in the engine being over cooled and operating at lower than optimum temperature. A side effect of this would be that the passenger compartment heater would not be able to put out enough heat to keep the passengers warm.
The thermostat is therefore constantly moving throughout its range, responding to changes in vehicle operating load, speed and external temperature, to keep the engine at its optimum operating temperature. "
Cheers!
Mrnazmi
510
29
3,028
Drag City
Agreed, thermostat play important part in bring the engine up to optimum operating temperature in and for sure for effective optimum engine when running..:driver:
tofu_manic
1,342
91
some also say better to install surbo and mikrokompressor
arturo
nooB
2,721
1,083
SateCelupLand
hahaha tofu...
if it's better to take it out, y do car manufacturers install it in the 1st place? wouldnt it be cheaper to not install n save some cost in parts? does that sound logical? everything is there for a reason. n the termostat is there to maintain the perfect temperature range for the engine.
kayour
326
41
mine...never remove it...since my 1st car and never facing any problem regarding it
i just warming the engine up less 2 minute every morning
SkYwAlKeR
10,139
300
ePoh ~ malacca
if ur mechanic say removing thermostat can cure overheating problem, ask ur mechanic dont be lazy to find out the root problem and solve it....
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
better yet.. change pomen :biggrin:
here my review about my first day after getting my car titaned.
well THUMBS UP for uncle richard,ah fai and stanley. they done a very very good job on it.
first impression when i test driver my car...smooth!!! the hard feel of course got lah..but can get used to it..then go back,ah fai ask wanna get some swing butt alignment setting.so i give it a go...so far one word to describe NICE!!!
the bump part is absolutely SUPERB!!!! it goes over it even better than my corolla.everyone was impress...
