Cams
danish
115
Hi All sifoos down here...
Please expend my knowledge by sharing info on -
  • High Cam
  • Re-grind cams
  • Lift?
  • what 272 stands for?
  • duration?
    Need help sifoos....
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
- highcam stands for high profile camshaft... they usually have higher lift or/and longer duration for better performance...
- regrind cams means a normal cam if being regrinded according to specs to have longer duration... there are also regrind cams where manufacturer take an iron rod and regrind it using CNC machine into a highcams...
- lift means how far the camshaft lobe can push the intake/exhaust valve... the more if can push, the more air/fuel can enter, the more performance u get...
- 272 stands for degree... i dont know how to measure or count lah... but 272 degree and below are usually meant for street use... 272, 292, 300, etc. are usually meant for racing...
- duration is how long the valve is kept open... the longer the duration, the more overlap of intake and exhaust valve will be...
mayb this link can help answer ur questions more...
Howstuffworks "How Camshafts Work"
Earlier this week i was approached by a friend and colleague to help detail Sanjay. Who is Sanjay? Well, it is this blue Saga BLM. I know. A sexy bollywood name right? This baby got hit and scratched while being parked. Not knowing how bad was it through the phone, I told her I'll see what I can do.
Look...
Closer look...
