Bring down Wira weight to 900kg!!!
William_Chee82
William_Chee82
39
37
Too all the sifu, I do need advice of hw to reduce the weight of my wira
I am currently driving a Golf GTI plus a Wira wt a 4G92 single cam (m)....
I wld like to convert my wira to be a half street n half track...my first target is to reduce the weight...
I do luv the Wira sedan alot...
1.I am looking is to replace the front bornet wt a lighter part example corbon fiber or fiber.
2. I am looking ppl tht do make the rear bornet lighter, maybe corbon fiber or fiber
3. any idea hw to take out all the seat plus the rear seat
4. any part I can safe the weight frm the wira???
Do hope all the cifu can help me by giving good pint of hw make my car lighter...forget abt all the JPJ rule.....
^pomen_GTR^
7,000 RPM
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
first step..empty your bonnet..including removing your spare tyre,tools,floor boards,carpets,plastic panel cover...
-remove seats and carpets..also replace driver seat with lightweight bucket seat....front passenger seat also remove...with a set of spanners u can simply remove the seat...just require some time and energy to do it alone....
-remove door panels,replace power window with mechanical winding type(or better fix window that can't be opened)
-use some thinner and scrapper to scrap all tar-soundproofing materials on the body...
and replace all four window with plexan clear plastic type window...
my bet...less than 900kilos of weight....
---------- Post added at 01:57 AM ---------- 6 hour anti-bump limit - Previous post was at 01:52 AM ----------
if u want to use your car for drag...then u can cut and remove so many metal from the chasis...
but if u want handling and chasis strenght..better to do double stitching welds/spotwelds to prep the chasis..and add rollcage...offcourse u will increase the weight back..but not much....
HKS-GT2835R
HKS-GT2835R
1,193
83
5,148
kelate
- air-cond system you still wan arr? that removes A LOT of weight oso.
^pomen_GTR^
7,000 RPM
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
yep..remove all aircond assembly including compressors and its bracket,heat exchanger in front the radiator,cooling coil inside the dashboard and all the pipes including its filter-dryer...left only the blower working to keep a breeze blow when u stuck in traffic jams.... :adore:
^pomen_GTR^
7,000 RPM
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
drags car usually use modified empty aircond gas tank as a replacement :adore:
g4i8y0t
g4i8y0t
1,216
330
683
Kedah
Replace the battery with lithium-ion type. It it supposed to be the best weight reduction mod in term of cost-per-weight ratio.
YYC
YYC
1,833
939
Lithium-ion battery for car? How, where and price?
I add on more: replace the roof with aluminum type.
^pomen_GTR^
7,000 RPM
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
where can i go for double stiched the chasis?
workshop that familiar with track and rally cars were the best place to drop by....
one located in nearby pjs 2...MRU motorsports.... :adore:
William_Chee82
William_Chee82
39
37
tq alot fr all the sifu advice....it really help alot....no I am not planning to enter drag race....my main objective is to reduce the weight to a very max plus is still able to drive ard city....I am going to remove all the seat this weekend n also the door panel n going to replace the front bonnet wt a lighter part.....
any good advice of wht rim shd i use...planning to keep it at 15inch ... sad to say tht I still need the air con bec sometimes I will be driving it to work...:burnout:
^pomen_GTR^
7,000 RPM
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
go for ori japaneese lightweight 15inchi rim...superb....
HKS-GT2835R
HKS-GT2835R
1,193
83
5,148
kelate
wat about change your fuel tank to a smaller ones?/ eheheheee.. nice..
yeah, agreed, but mahal la that one.
sure looks cool tho.. :biggrin:
---------- Post added at 12:44 PM ---------- 6 hour anti-bump limit - Previous post was at 12:43 PM ----------
if on budget, taiwan makes cheap liteweight 15" oso :biggrin:
you cud oso rentung-ize yur car, but then sure illegal one.
heres summore list of shit to remove to get you started :
back seats
passenger seat
carpet
sound deadening
spare tire
jack
stereo
speakers
power steering systems
power window remove, ganti with those pulas one..
plastic panels
roof liner
bumper supports
interior door skins
dash board
air bags
replace rear windows with lexan/plastic
center plastic (arm rest, shifter area, etc)
put in a roll cage, remove seat belts get harnesses (do not get harnesses without a roll bar / cage)
CF or Fiber body panels
replace driver seat with stupidly light racing seat
replace side windows with lexan/plastic
replace windsheild with lexan/plastic
light weight battery
light weight drag racing front brakes
remove rear brakes
the actual list goes on and on ..
gIGoN
gIGoN
327
hi guys bumping up this old topic. I'm converting my car to full time drag machine.
Desperately need to know WHERE i can do the below:
1. Carbon fiber rear bonet and doors
2. Replace all windows with plastic/lexan
3. remove dashboard and wirings and replace it to race switch type cockpit
4. spot weld body
Supra_Fanatics
Beyond 20,000 RPM!
Supra_Fanatics
Beyond 20,000 RPM!
20,674
3,998
lose weight... :biggrin:
If weight 80KG, lose 30KG means car lighter by 30kg :rofl:
Funny betul but does make sense...:rofl:
Nothing else more to add in this thread in making the car lighter...
gIGoN
gIGoN
327
my concern is not on what more to add to contribute on shaving those weights. i need to know where to do it based on my query. hope someone could help out.
^pomen_GTR^
7,000 RPM
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
do it at home for me.. :driver:
4. spot weld body
1) just buy and install
2) look around for signboard shop that sell acrylic board in bulk...cut into size at home and install at home
3) dashboard wiring just tuck inside...race dash need more pro installer...i think in zth got some shop do this job...need to look around yourself (again if me just do it by myself at home)
4) big bodyshop that have spotweld machine (me got only MIG weld...so weld like taik cicak only)
fazidk
fazidk
3,163
413
5,183
Hi bro...just asking regarding d acrylic u suggested...can it stil b operated like a normal window aka up down operation (auto or manual) or is it a fixed thing like real race cars??
Ur reply gr8ly appreciated
Tq n rgrds
quicksilver7
quicksilver7
313
66
528
4. spot weld body
hey bro should remove rotating mass too. for e.g. lightweight flywheel, lightened crank pulley, get smaller and lighter rims. and if you're crazy enough, lighten your crankshaft, get lightened pistons, lightened conrods XDDDD
^pomen_GTR^
7,000 RPM
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
Tq n rgrds
fixed....because when chasing lightweight....might be better throw away the window up-down mechanism also....
but i think it is possible to keep the winding and use it on acrylic windows...this just opinion..not tested
