Best Fuel Savers in the world
cik_yat
384
Miami
wandianagarageinc.blogspot.com
ETC if not mistaken is a replacement for conventional cable pedal.. so that car didn't use a cable on acceleration pedal..
All cars have standard setting with used to maintain the lifetime and reduce the maintaining cost... and of course small cc will have a low FC compare with big CC and depend on type of engine... sohc, dohc, V6, V8 and rotary also have a different FC even the CC is same.. V-type engine suitable for cruising or long distance... rotary consider as high performance engine and the FC is also high.. common engine is only sohc and dohc while acceleration for dohc is better than sohc.. to get a better FC, use a suitable car for a suitable journey, with a suitable driving style...
donCityZ
2,230
33
ETC is pretty simple device. It just bypass the signal of your throttle sensor. U press sikit, the sensor tell ecu u press banyak. lidat lor.
all are good device to make good business.. muahahaha
bladerunner
544
the throttle control which advertises fuel saving is actually just another gadget that makes another fool part with their money.
the gadget actually just amplifies your throttle response, so in return no saving is achieved
so, the best fuel saver is actually the nut behind the wheel...
sifu sifu want to ask your opinion on the breather hose..my engine after driving for a while then back at home, i notice the breather hose coming out some asap not much just like engine oil is hot..fitted with oil catch tank and temp gauge read 50c to 60c.. but i not very comfortable with the slight asap coming out from the breather hose...is it cause by the wap of the engine? or engine trouble..
currently car fitted with oil cooler,gear oil cooler, change all valve seal,gasket top to...
