B16A To B18CR ?
HanJackaL
1,013
11
PJ
Hi guys,
I am just wondering which would be a better choice, buying a B18CR straight away for RM 16 k, or buying a B16A, then modifying it.
However,theres a few things i am unsure about.If i buy the B16A, and put in my own custom Cams,ECU,crank and change the Head from B16A to B20B or B18C, will it be better or equal than the B18CR ? Also,lets say if i buy the B16A, can i rebuild it to B18CR for a cheaper price than buying the whole B18CR complete engine ?
Lastly,can someone give me a break down on what the Engine block and head is made of ?
Engine block = Pistons,Piston rods ... ?
Engine Head = Camshafts,crankshafts,valve,valve springs... ?
Those above parts of the engine is crucial in improving engine performance right?So that means,i can use a B16A and even make it out perform a K20A just by changing the above parts to the "best" ones there are in the market? And that also means that a standard B16A can be rebuilt into a B18CR just by changing the vital parts to similar parts or better of a B18CR ?
Any advice on this matter and engine conversions are greatly appreciated!
Thanks bros !
HanJackaL
1,013
11
PJ
white_bird said:
my advise.. B20B rojak!
B16A - B20B rojak ? Is that a good choice?Will that be better than a B18CR ? Lets say both are HEAVILY MODDIFIED...
THanks for response bro !
dev
209
Pert, Australia
B18C Type R, better choice... no need change this change that... less headache.. if u rojak it will cost u more in a long run... B16A to 2L idle also like want to mati mati.. then to stable it need to spend money again 4 ecu, piggy bag n etc... so i think B18C Type R will b the best choice.. but depending on ur budget also.. if u think u want to R&D then, B16A ---> 2L.. :smile: if u those dowan headache then u know wat im goin to say rite.... all the best!! hope u make the rite 1, n dun regret like me.. :frown:
crxr
721
5,018
If got budget, go for K20a, newer engine n more fun 2 play but will run in between rm20k - 25k install stock standard.
white_bird
643
puchong
u want kao tim 1 time then b18c-R lor.. but some ppl like to modify.. really modify.. from 1.6 change block to 2.0.. ermm.. how to say.. more challenge n satisfaction i think..
HanafyEG
831
change the block to b20b..no hassle at all..the block with internal would only take 1 month to prepare..at the mean time u can just use ur current engine for a while..then when the block finish, just sent ur car to fix it..it would take about 3-4 days only..i did it last time for RM6k..still using it now..no problem..the tork is awesome man..
HanJackaL
1,013
11
PJ
Thanks for the responses guys.
Am i confused when i say Engine Head is made up of Cams,Cam pulleys,Valve retainers and springs..etc ?
Or is the engine head a part of its own ? Like engine head is engine head, just 1 piece of metal ? =P
Or i need a BIGGER head to fit in the better cams ? Just like i need a BIGGER block to fit bigger and higher compression pistons ? =P
dev
209
Pert, Australia
cam pulley, camshaft. valve n so on is in the head... thats all component of the head.. without that the car will never start :biggrin: o move... all that move mechanicaLLy by the timing belt o chain...
DarkFibre
239
Bro!,
Where did you do the mods man? care to share it with the benefit of others?
poison
84
hanafyEG has a monster civic there....don siao siao ...hear at his advice la HANJACKAL...its worth...y not jz modify it into a v-tec turbo? b18c turbo?
aku_sangap
1,172
15
Tengah Laut
hahhaa..listen to hanafyeg dude...he's damn rite about the b16a+b20B...ehehehe.....want more?..turbocharge it!!...then, after that..u car can fly.....
HanJackaL
1,013
11
PJ
Hmm....So i buy a B16A half cut and just throw in a B20B head? No additional mods needed to allow the B20B to run properly ? Will the pistons be too high a compression and end up spoiling the engine or making the Engine lag ?
Let me know please...Also, where do i get the B20B conversion done? And what do i do with my B16A block after i throw b20B inside ?
Thanks !
white_bird
643
puchong
dude.. it's B16A head n B20B block..
high compression wont make ur "engine lag".. haha,.. u tot turbo engine ar?? high compression is good for NA..
xcheong
1,650
actually u got it confuse hanjackal.
u goin to mate your B16A head with B20B block. that's where all your massive torque come from kekek...
https://youtu.be/l-zDt9FGJi8
This is the difference..pretty interesting to learn this. izso you knew about this?
I love it when people tell me that their Sumo engine oil, their "racing" oil, or their JTX engine oil damn good.
A glimpse inside Mobil 1, and I believe the big boys like Shell, Total, Castrol would have something similar in terms of R&D.
Oh, and keep your "race proven" engine oils. Race engines are rebuilt annually or after EVERY RACE. So unless you rebuild...
