Auto Transmission Fluid(ATF)
jaydee123
145
I'm using a Proton Wira 1.5GL(A). I'm yet to service my auto transmission fluid. my mileage is 52K.
I would like to know about the AT dip stick. It has 3 part.
Cold, Hot and Adjust when is hot.
What is the meaning of all this 3 parts along the dip stick of the gearbox?
Please help.:_:
Oct 5, 2006
4
Cold is when the engine has been shut down for several hours and is in its ' cold ' state
Hot is when the engine is at its ' operating ' temperature which means driving the car for perhaps 10 mins .
Make sure the car is on a level road when checking your fluid level .
for 52k , I suggest you go and flush your ATF and replace with Proton ATF .
Cost is approx RM38 per ltr .
anakin
104
kl
any other brand than original ATF that's giving better protection to our gb?
jaydee123
145
i ask SC today, they say i need to replace ATF, gasket and filter all for RM270.:baring_teeth:
acbc
4,615
8
KD
U should service the auto gearbox every 20,000 kms. Less if u always rev 6000-7000 RPMs daily. I service mine every 15000 kms using Castrol ATF. Good enough until my next gearbox rebuild project.
jaydee123
145
but u do not change the gasket n filters??
siangmh
199
i did mine: machine flush ATF + refill proton ori ATF for a quite cheap price
Non-ori bulk barrel dexron 3 ATF : RM9 / litre (provide by mech, for machine "washing" auto box use, the cleaner d autobox, the less consumption of this fluid, i use a few litre only)
Ori Proton ATF : RM19/litre (for refill-up clean ATf fluid, i used 3 litre only) (bought fr spare part shop)
Ori proton ATF filter: RMXX (forgoten how much, but i think < rm40)
Labour : about rm50
Additional treatment : add in if u want (eg Lubegard rm50 per small bottle)
So cost wise < rm270 as u mentioned above
Helo, need help.. Planing to change my absorber to adjustable so im wondering which is good for long traveling n bumpy road, kyb rs pro or zerone ssr550?
Tq very much for ur guys reply..
