I used to change 2 pcs every year, now change every 5 years even though still not finish, but harden......lolHow the hell u guys drive 4 years with 1 set of tyres? I change 2 pcs every half a year.
Drive like normal drivers do. I get about 50 to 60K mileage for each tyre change. and using eco tyres XM2.How the hell u guys drive 4 years with 1 set of tyres? I change 2 pcs every half a year.
oh myHow the hell u guys drive 4 years with 1 set of tyres? I change 2 pcs every half a year.
i think depends on the tires compound oso. i bought toyo NE03 for my wife citra, year 2016, installed 2017. 4 years use the thread still thick but the compound harden. also maybe due to bad suspension and 1 slightly bengkok rims, after swap new suspension can feel the tires pulling everywhere even after done alignment twice. now swap to yokohama ES32 year 2019. let's see how long this one last.Drive like normal drivers do. I get about 50 to 60K mileage for each tyre change. and using eco tyres XM2.
talking about tyres. i note now tyres starts their life when installed on rims. so instead of getting less than a yr / half yr fresh tyre. you can get 2 yrs made tyre and use it for 4 yrs or until it wear or 40/50K km
TR1, ATR Sport, both hard tyres but still eat a lot, i guess car heavy and kuat cornering lol.Huh so fast?? What tires do you use and how many km travelled yearly? For me, I use UHP tires with tread wear around 280-320, roughly can last 40-50k km. I do rotation every 20k km.
TR1 is 280 TW so a bit softer but ATR is 400 so should last long enough. My Mark X also never rotate because staggered wheel sizes but the wear is quite even hence all 4 can last at least 2-3 years with 300 TW tires. Probably you drive too fast! I drive slow2 only, typical uncle drive. LolTR1, ATR Sport, both hard tyres but still eat a lot, i guess car heavy and kuat cornering lol.
I follow VR2turbo's advice, just use the fronts till botak since its FWD. then swap the rear to front.
Changing a pair soon. Take my usual speed at corner already making noise ahahha
Huh so long? Zestino on your 7 right? You seldom drive it and short distances only la.oh my
i suspect, mine thread wear 140 also will last me 3-4 yrs all in
Frm my exp using normal tires, high speed drives does not have significant increase in wear. Its weight and cornering. I got a friend shod his Honda Stream with Toyo TR1 (or is it T1R...the older model) and that lasted just abt 1 year. That car is loaded most of the time.Total mileage is well below 40k km.TR1 is 280 TW so a bit softer but ATR is 400 so should last long enough. My Mark X also never rotate because staggered wheel sizes but the wear is quite even hence all 4 can last at least 2-3 years with 300 TW tires. Probably you drive too fast! I drive slow2 only, typical uncle drive. Lol
Weight and especially how aggressive you corner dictate a lot on tire wear. Cornering hard usually wears out more on the outer treads though.I tot thats the
4x4 tires are an exception. I am referring to 4x4 and not SUV. AT tires seems to last long, quite long actually. Its either due to the at least 4x thicker thread (compared to car tires) depth or different compound. Other HT tires seems to wears out like a normal car HP tires.
Finally know the TW lol because couldnt find the number at all. However the TR1 performs like shit in dry compare to ATR Sport. But wet TR1 triumphsTR1 is 280 TW so a bit softer but ATR is 400 so should last long enough. My Mark X also never rotate because staggered wheel sizes but the wear is quite even hence all 4 can last at least 2-3 years with 300 TW tires. Probably you drive too fast! I drive slow2 only, typical uncle drive. Lol
daily... but maybe 25km a day...wah that long? daily driven or not?
wah you can tahan so long...mine will be finish very quickly ahahahaoh my
aiyah, i drive max 90kmh je~ never in my life passed 90kmh~wah you can tahan so long...mine will be finish very quickly ahahaha
Oh TR1 that bad huh? Thx for the info.Finally know the TW lol because couldnt find the number at all. However the TR1 performs like shit in dry compare to ATR Sport. But wet TR1 triumphs
Yeah right!aiyah, i drive max 90kmh je~ never in my life passed 90kmh~
*edit,i think this time i wana go with 90
his typo problem. Should be 90mph.he had the number "1" in front for breakfast.... hungry liao... hahahaha....
TR1 not for you lah, even I used before T1R in VR cannot hold in the wet. Drop 3rd gear in the wet can wheel spin.....lolOh TR1 that bad huh? Thx for the info.
Yeah right!
Even that still questionable!his typo problem. Should be 90mph.
That Gent is a questionable person.Even that still questionable!
Thread starter | Similar threads | Forum | Replies | Date |
What is the maximum price you would pay for rims. | Wheel And Tyre | 69 | |
Maserati Ghibli Second Hand Original RIMS TITANO 21" | Wheel And Tyre | 0 | |
Wheels/Rims/Roda | Wheel And Tyre | 106 | |
M | AD rims. Has anyone heard of it or has one of it? | Wheel And Tyre | 0 | |
F | Need Advice: Rims & Tyres 15" ; Cheras | Wheel And Tyre | 10 |
