apexi turbo timer - timer not function
ondgennis
299
Malacca
hi all,
i facing this weird problem. i have an apexi turbo installed for the last 2 years and it was working fine.
until this week, the timer function most of the time was not working anymore. when i off the car, the timer's screen go to the timer section and it off before the count down start >.<
i have redo all the connection but it still having the same problem...weird case it do work once in a blue moon (1%). fyi, i also ground the grey wire (connect to handbrake) so that the handbrake function for the timer is not being use.
pls help...
jj.v6
332
13
johor baru
might be spoil..how bout the other function..a/f ratio?battery ?
if the rest is working then something is wrong with the wiring part..if all not properly working then u got to find a new one..
tUrBiKss_pRoToN_vR4
72
SELANGOR
the timer count down chip data will fail some time..but usually it takes till 5 years if its original timer u used...my opinion fine new one la..heheh... :biggrin:
ondgennis
299
Malacca
others functions all working fine, only the timer is not working.
maybe it really 5 years time already because this timer i also buy used one.
really no others solution?
ondgennis
299
Malacca
i have a pivot baby timer :)
anyone know how to connect n make 2 of these work together?
apexi - volt n AF reading only
pivot - timer
ondgennis
299
Malacca
just dont waste the resources mah.. :)
so anyone know how to connect the apexi timing without the key ignition?
LuKa
618
19
Kedah
Apexi timer is rm280-300++ already now for new black case red/blue led... not cheap... add a few can get HKS new timer Type0 already
Anyways.. i like the pen timer.. small n very easy to place almost anywhere.. if planning to buy.. its better buy ori ones bro.. ftzone got them.. can buy from him..
ondgennis
299
Malacca
finally i able to hook up my pivot baby timer together with the apexi.
so now the apexi is use for the volt, o2 and AF reading while pivot for the timer function.
anyone know how to do tunning for car's ECU? means, change/remap the setting for better control and other stuff, eg.fuel consumption... thanks.
