alternator problem? ??
satbir_91
Dec 7, 2011
16
503
Last week my car, wira se alternator kong d. So I changed to a new one but made in taiwan wan la. Thing is after changin that my mechanic aso tighten my fan belt n all coz I told him gt squeeking sound. Probem now is that after these 2 changes I notice that when I press my accelerator pedal n the rpm go up..my headlights get brighter, my air cond blower get stronger. B4 the change all this nvr happen. So is it bcoz alternator faulty or belting too tight? My car feel very heavy also la..last time easily can tpuch 140 plus now touch 120 aso problem la.
What I did so far: I started the car and on air cond maxm on radio, on wiper, on lights, and then disconnect the negative battery terminal. Car nvr die...still jalan. I waited for almost 5 minutes car nvr mati. Someone pls advice what is the problem. B4 the alternator n belting had no problem
Beyond 20,000 RPM!
29,998
Ask your mechanic to check the charging voltage of the new battery and also check the voltage regulator.
Lights becomes brighter means voltage is higher....
sharif5865
Jan 24, 2012
13
Kuantan
May I ask something,,
1. Is it normal that baterry indicator to lights up even after few seconds of start engine?? but this thing only few times....,, I use "bateri basah" not the free maintainance one..
2. Did altenator effect the top speed of the car like he said??
twistedichc
Jan 22, 2013
2,930
255
683
Ampang Point
1) Same thing wit me, so far no prob
2) i learnt that the main function of batt is to start the car, than the job is taken by altnr to run those e-equipment, if alt cannot support than it will consume batt, e.g u'r sound system takes more than the alt can support, top speed i think we need to ask sifu's around arrr:banghead:
---------- Post added at 03:00 PM ---------- 6 hour anti-bump limit - Previous post was at 02:52 PM ----------
DIY testing of alt:-
a)Multi tester @ Batt/Alt tester (found 1 @ ace hware +-RM25)
b)run engine, on all lights, radio anything electrical, take off +ve batt (make sure not touch body) & test voltage +-13V is ok, 14V++ overcharge <12V kong already
c)turn off engine, take out -ve batt than only re-install batt terminal +ve first
sifu's correct me if i'm wrong:biggrin:
Beyond 20,000 RPM!
29,998
b) you tested the battery voltage only? With the +ve terminal out join the tester in between the +ve terminal and battery +ve to see alternator charging voltage
twistedichc
Jan 22, 2013
2,930
255
683
Ampang Point
thanx forgot bout the -ve probe, wit that i check other site & :banghead:i got it quite wrong big time:banghead:
just type car alternator check @ search engine wallah so many
check back the alternator pulley same size or not....
and battery get it fully charged first and see...
normally that shows not enough charging current coming out from the alternator.....
hi there ,
does anyone knw where can i get the replacement of the remote control ( Transmitter ) for viper 560xv alarm ? how much it costs? it can be repaired??currently i'm using the spare one ... please help ..thank you
