Again PCD 100 - PCD 114
cheng_Y
cheng_Y
Aug 5, 2011
17
503
I had read & hear a lot of member changing their Wira PCD 100 to PCD 114 using below items
- EVO 3 Knuckle
- GSR Knuckle
- FTO Knuckle
- Spacer
But Unfortunaly I bought FTO knuckle wont fit to my Wira SE 2004 drive shaft. (The drive shaft Gigi no equal)
Just to ask which knuckle just plug & play for Wira without change the drive shaft ( Front Set, rear no problem?
Why change PCD 100 to PCD 114?
- Fit pretty after market offset rim, such as Buddy club P1 Racing offset 22 / 27.
BoxCarRacer
BoxCarRacer
524
103
1,543
Johor Bahru
Why not just drill the hub and relocate the stud to PCD 114? it is much easier. I did that on my neo before for PCD 114 -> 100 conversion and after 5 years, i have not encountered any problem with it.
Please use a proper center cone in between the hub and the rims. That what makes the wheel centered onto the hub.
Btw, my 15" P1 Kosei buddy club with offset +27 is PCD 100. What rim size you're on?
DanzEterna
DanzEterna
15,914
3,371
PJ
www.primeperdanaclub.com
simplest way just get a set or pcd 100-114.3 spacers. bout rm300++.
but its better to get the hubs drilled.
i manage to find 114.3 x 4 8jj/9jj p1 buddyclub 17" white.
many 114.3 x 5 in the market.
cheng_Y
cheng_Y
17
503
BoxCar Racer - the outer diameter of neo hub is bigger compare with wira. It will unable to drill the 114.3 hole with wira hub, the hole is too near to the end of the hud diameter (Too dangerous)
Danzeterna - dun wan use spacer. If use P1 racing 16inch 7.5j offset +22 PCD114.3 + another space 1/2 inch = I get offset +10.. too much for wira.. Target offset for my setting is +27 or +22 is enough..
Slipar - Yup, from the foreman. But, I might tipu by halfcut ppl (Not sure). As I know FTO,RVR,Eterna. the hub is same.. Maybe the gigi of the CV joint is different or the drive shaft diameter is different. SO head ace...
^pomen_GTR^
7,000 RPM
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
just get evo3 whole knuckle set front and rear
kaihoong
kaihoong
93
8
25
Penang
- EVO 3 Knuckle
- GSR Knuckle
- FTO Knuckle
- Spacer
Might you share your Wira SE suspension setup for riding and handling experience to me. Engine remain 1.5 or already convert
ixeo
ixeo
4,787
3,080
KL, Malaysia
Forgive my stupidity.. that's a lot of work for the rims. Unless as part of the change you get to upgrade to Evo brakes as well then its worth while..
Beyond 20,000 RPM!
Beyond 20,000 RPM!
29,878
8,347
  • Like
Reactions: minibeany
sweelt
sweelt
Nov 6, 2016
2,292
246
663
Penang
sweelt
sweelt
Nov 6, 2016
2,292
246
663
Penang
how? its special, because you can OR funny & stupid depending on who you ask.
why? got to ask the previous owner
actually trailers use 8 lug wheels right? i can claim to drive a mini trailer~
is special indeed, just little extra work when remove all 32 bolts.
