Welcome to AfterTwelve E-Garage!!!
We do shipping internationally / COD / Credit card accepted.
We provide installation and painting as well.
Some item's price quoted below including installation or painting.Please take note.
Any kit that you are interested but not listed here, please contact us.
Pls Contact JACK 012.312.7113.
DEALERS WANTED!!!
Whiteline W51988 Control arm - lower inner front bushing for Proton RM285
-Worn front control arm bushings have a huge influence on vehicle stability and braking efficiency,
-Replace these worn bushings with Whiteline control arm bushings for chassis control.
Available for:
-Proton Wira, Satria, Gen2, Waja, Persona.
Whiteline Control arm - lower inner rear bushing (anti-lift/caster correction) RM319
-Designed to add 0.5 deg static positive caster to both front wheels while changing the nature of front anti-dive & lift.
-The low compliance bush also maintain higher dynamic positive castor.
-This leads to superior traction under power including cornering & dramatically reducing understeer & front wheel spin.
-New firmer bushings supplied serve to dramatically sharpen initial turn-in response then forcing more consistent alignment angles through the corner due to the reduced bush compliance.
Available for below models:
-Proton Wira, Satria, Waja, Gen2, Persona.
Whiteline W13206 Steering - rack & pinion mount bushing for Proton RM215
-Induce positive steering precision and feedback,
-Reduce noise.
Suitable for:
Ready stock.
DEALERS WANTED!!!
Kindly contact After12 at 012.312.7113. for more information.
DEALERS WANTED!!!
Available for:
-Reduce noise.
Suitable for:
Ready stock.
DEALERS WANTED!!!
