Vibratile is a new generation lightweight sound and vibration solution for use in motor vehicles that is applied to the doors, fender, roof and/or other body panels found on the vehicle.
The conventional method adopted by car manufacturers is by adding more weight to the structure. Weight addition burdens the car as it increases fuel consumption. Vibratile is developed as a lightweight and instant panel hardener as an alternative solution.
By simply attaching the conveniently sized self-adhering pre-cut, multi-laminate "tile" onto any body panel in a vehicle, panel noise and vibration can be reduced significantly and noticeably by as much as 70%.
With Vibratile installed, a vehicle will achieve a new level of noise control that would greatly enhance driving comfort and enjoyment.
How it benefits you
A new level of noise control to enhance driving comfort and enjoyment.
Eliminates tin-can panel ringing. Body will exhibit a solid "Euro-car" accent.
Suppresses structural, engine and road borne noise & vibration by hi-tech metal conditioning.
Kills raindrop ringing intrusions when installed on the roof.
Instant door panel "hardener" when installed on doors.
Improves your sound system by cutting off induced & external resonance.
Only a few small tile-sized pieces required for a dramatic difference. Lightest effective material available.
Negligible weight penalty. Vibratile is the lightest weight effective material available.
Comes ready shaped and is self adhering for easy installation.
For more details and pictures viewing, please refer to http://teamcity.proboards31.com/index.cgi?board=group&action=display&thread=1139825969
How it benefits you
