4g93T 6 speed conversion?
jeffy
47
Anyone tried? =DD
Possible? any ready aftermarket stuff to mod?
Plz share..
jinkl
4,624
376
3,183
not worth it i guess, making a custom bellhousing will cost few thousands i guess
lavodo
159
y need 6 speed? hmmm.. not enough topspeed? just change ur final drive or ur 5th gear..
UnicornSpeed
197
i heard year ago a rally satria been aprove by fia using 6 speed...6 speed will cost so much money
shiraballistic
75
i guess having 6 speeds will have its advantages, if possible and the price quite reasonable i guess i too would want one. :itsme:
ken yeang
6,000 RPM
6,617
1,327
To fully utilize the 6 speed gear box (regardless of the ratios), it's advisable to have an engine with enuf grunt first. If not convinced, just try riding a 21 speed racing bike. It's not easy to pedal the bike when using the top gear because lack of pedal power. even when you are peddling on flat ground.
Trinityblood
3,371
21
no need 6th gear,buy dog box enuf edi..cost 17k-25k ask jinkl he noe where to get it...hehe:listen:
boyzone
2,669
38
5,148
6 speed gearbox might not so heavy duty compared with 5 speed gearbox.
This is because of normally ppl will reduce gear teeth thickness to gain empty space to slot in #6 gear teeth.
Unless u have total new design / gb housing to support, if not ur gearbox will not stand long.
shiraballistic
75
normally ? so your telling me some poeple are already doing it ? I for one don't think it is that easy as to reduce gear thickness of each teeth and putting an extra gear in.
How would a dog engagement be the same ?:confused: totally different from a 6 speed.
i do understand that top gear might strain the engine, But u could increased the ratio of 1 - 5 and put in a 6 gear that retains the original fifth gear ratio. Now you have something that might work , not ?:hmmmm:
While the primary focus of tuning is still very much on the Nissan GT-R, its smaller cousin, the Nissan 370Z, is still getting its fair share of attention from the tuning houses.
Senner Tuning is the...
