4g1* engine oil pressure
Amir Kim
Jan 14, 2014
13
recently my 4G15 wira had low oil pressure, engine oil ever go to cylinder head.. can i ask any suggestion to increase my oil pressure?.. and this evening i open my engine oil pump, and i notice my oil pump doesnt have relief valve/relief spring valve.. does this normal to 4g15 oil pump? btw this is my 1st time opened 4G15. hope all sifus here will help me
How do you know low oil pressure? You have oil pressure meter?
Usually need to change the oil pump if faulty....
If you've dismantled the oil pump, means your engine is all over the place now? Take some pics la
synail
259
19
Try placing back the relief spring and plunger, might be the source of ur weak oil pressure
Btw how come ur oil pump don't have it
Hi all,
I'm planning dump in a 4g93 block into my current 1.6 mivec. At the mean time, should i remain my current mivec gear box or change to 4g93 gear box for better performance?
