4E-FTE ENGINE
ssgt4e7882
21
HELLO GUYZ,
NEED HELP!
MY CAR PROBLEM IS WHEN I PULL MY THROTLE UNTIL 5500RPM ONWARD, MY MACHINE WAS JERKING...DUNNNO WHY?
I HAD CHANGE MY COMPUTER BOX, IGNITION COIL, CABLE PLUG, SPARK PLUG (USE THE COLD ONE) THE PROB. STILL APPEAR ..
MY HEAD WAS CARCKED NOW... NEED OPINION A.S.A.P
TQ
-4E LOVERS-
CcL
506
5,018
me having same problem too
when i hard throttle my car it'll jerk
i've checked all that u've said but couldn't find the problem
you said u changed the computer box? you mean change with an OEM or motec/haltech etc etc??
for my case i suspect it is the knock sensor retarding the timing thus the jerking. why? because when i hear pinging my engine doesn't jerk. but when it jerks i don't hear pinging. weird? *shrugs*
when i get a piggyback in i'll confirm if its the knock sensor loh..... you can also check your fuel pump and fuel regulator! ;)
bujang_hensem
82
yeah maybe you are running lean...ECU retard the timing....try upgrade your fuel pump to bigger one lor and don't forget to change the fuel filter also....it is cheaper than changing the ECU....btw how much boost you are running now 1.2bar?
ssgt4e7882
21
thanx guyz,
bujang hensem,
i'm running on standard boost ma ... 0.65 bar only
dunno why ... bcoz before this poblem came i'm just running 0.8 bar ... suddenly when i check my spark plugs its fuel is running lean ..
so, take off the 'tulang ikan' to maintain standard back
ccl,
i just changed to the oem computer box...
what do u mean 'knock sensor'. is it the map sensor ?
lekalo
754
TTDI
fuel pump!... try bigger one.
how many litres per hour is normal 4E's pump arrr?
speedmax2001
135
check ur fuel pump, fuel filter, n fuel rail...last time i oso having the prob like tis..after i changing tat item..prob fix..
keong_GSR
1,009
try to get d rx7 fd or fc fuel pump n regulator... i boost 1.6 bar also no problem till now... 200bhp on 1.6bar dyno tat day in GT...:_:
xtremeleo
3,247
464
5,183
i suspect its the fuel pump, std 4efte is capable of doing 190liter/hour.
bujang hensem : hasnt seen u for years, u r still using the perdana turbo rite?
keong_GSR
1,009
190 lph? i dun think so... evo3 fuel pump only generate 145~170lph leh... as for d rx7 FD 3S,d flow rate is 210lph...
samuelccy
408
KL-Sentul
bro, juz tumpang ur thread ... I'm using 4AFE bolt on turbo kit .. tend to upgrade my fuel pump as well ... what fuel pump shuld i go for n how much it will cost r?
xtremeleo
3,247
464
5,183
keong, u have to remember dat an evo has 2 fuel pumps, a 4efte fuel pump is bigger den AN evo/GSR fuel pump. note dat iam comparing ONE unit between the two pumps.
keong_GSR
1,009
xtremeleo,
stock pump will never enough if up ur boost or tweak ur engine...:_:
Hi All,
It has been over a year and 8 or 9 months since I last shared my epic journeys. So before we move on to the detailing journeys, let me share with all of you.... oldbies and newbies on what I have been doing during the long hiatus.
First off...... I went and fulfilled one of my dreams which is to hike up Mount Kinabalu to see sunrise.
Then upon returning..... I got myself a really...
