4agze loosing power while boosting
gtz4agze
7
new zealand
i have reciently put a 10psi pullry kit on my 4agze but..... when i get to about 5-6000 rpm it starts to
get slugish! is it the factory computer thinking there is to much air?? do i need a piggy back thing (technical term) for the gas and air flow?? help!!!:banghead::banghead:
miriguy
887
20
its a knock sensor issue. i assume u upgraded to a 14psi pulley?
miriguy
887
20
originally is alreadt 10psi pulley. or did u upgraded to lightweight pulley?
miriguy
887
20
yr motor is from the AW11? try tighthen your belt. belt needs to be tighthen also after a few laps
gtz4agze
7
new zealand
motor is from ae101 tryed to tighten the belt didnt work. its weird it happened as soon as i left the work shop.
scoupe
1,087
37
5,148
shah alam
hmmm i thought ae101 suppose to have 10psi pulley.. are u talking bout the power dip at 5.5k rpm?
gtz4agze
7
new zealand
had a 8psi standard one. yea has a power dip around there did do it before but powered through it now doesnt power through it
baby_cky
24
check your charger u runing on air flow type or map type????
my use to hav tis problem but my is piston problem
Just doing a research on these 2 manifolds and wondering which is better.
As far as i know mivec manifold is good but its very heavy (cast iron) and hot bits is proven. Your ideas on this guys??
