need help for engine mods in a 4g13p proton saga engine
series5401
373
17
Kuching
different displacement engine will have different gear ratio n final drive.
however, ppl do use bigger cc engine but retained their lower ratio gearbox, so it pulls much better and torquier.
factory made gbox ratio to match the engine displacement, their goal is to output optimum power n fuel saving, not performance or acceleration.
example, if using 4g13 gbox with 1500cc engine, 1st and 2nd gear can wheel spin like nobody biz, and playing between 100-170 is fun, but maximum is about 170kmh.
if using 4g15 gbox with 1500cc engine, 1st gear wheel spin only, 100-170 is not as fun as 4g13, but better top speed 180kmh++
but some claimed the new robocop design saga with 4g13 engine n its gearbox can hit 180kmh, maybe their gbox also different again. have to check the gearbox code.
anyway, 4g13 and 4g15 gbox codes are different
wats your suggestion,
if i want to still used my 4g13p engine..
do i need to change my gbox to 1.5 cc or 1.6 cc ones..
or just maintained it..
currently im using iswara lmss..
wif simple mode..
Newbienissan
Banned
Jul 19, 2010
279
17
earth
just find a 4g15 blok n plonk into it. when u have more $$$ get weber dcnf. that's enough for 4g15....otherwise u will be spending too much n regret coz u can have better engine swap for all the $$
series5401
373
17
Kuching
just used 4g15 block? iv done my p2p n oversized to my 4g13.. eheheee..
dcnf? currently using it.. but still trying to tune it.. webber is oke, just that its choke doesnt work, so morning have a difficulty to start up my engine..
Newbienissan
Banned
Jul 19, 2010
279
17
earth
then just get the weber dcnf, good enough :)
using weber, b4 u start the engine in the morning, pump ur accelerator a few times. then let the engine revs 1500rpm for 30 seconds. kautim. for the aircond solution, maybe ficd will solve the problem on aircond idling
series5401
373
17
Kuching
thanx 4 d trick.. eheheee..
btw, currently im using a 16 inch rim, taiwan.. my foreman said that it is heavy..
do u have any suggested rims fitted to my car.. as i know, the bigger the rims, the larger the diameter.. then long can play good enough.. if let say i change to 14, my long will reduce is it?/
Newbienissan
Banned
Jul 19, 2010
279
17
earth
14" inch will be perfect. 15" still ok if u use 50series sport tyres but its not going to be comfortable.
i will recommend 14", coz saga so light doesnt need 15"
series5401
373
17
Kuching
wats the meaning of light and doesnt need 15?
ehehehee.. my ori rims is 14 but not so nice..
aahhaa.. think to take a spoon taiwan 14 inch..
tq again bro..
apai_Ngage
337
3,018
Nowadays, 4g91 twin cam mitsubishi is around 5k if i am not mistaken
I was browsing through the net and I found this in Mudah.com. It look pretty obvious that the defi's that this guy is selling WITHOUT the sensors and for the Price.
Now I wont say that this item is 100% stolen. I might be wrong. MAYBE the guy lost/spoil all his Defi sensors and decided to sell his defi for a super duper cheap price. Anyway maybe any members in this forum that their defi's and other meter that been stolen able to recognize their belongings...
