How: Build 4g93 n/a full race
lae
10
HOW: BUILD 4G93 N/A FULL RACE ?
stage 3 , buid engine n transmision ?
any prefferr ?
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
- crankshaft porting and balancing...
- high compression piston... sleeve ported and balanced...
- stronger conrods...
- dry sump wif oil cooler...
- highcams... double valve springs... titanium retainers n stoppers...
- 4 throttle unit...
- larger injectors...
- standalone ecu...
- 4-1 extractor... straight piping out...
- 6 puck twin plate clutch..
- racing flywheel...
- dog engagement gearbox with straight cut gears...
what else ah?
tofu_manic
1,342
91
5,148
-ported & polished head
-ceramic coated piston head
-ceramic coated valve surface
-friction-reducing coating at piston skirt
-multi-spark-discharge ignition
-water-methanol injection
-fuel chiller
-custom crank scraper
-k2n power system from russia
i think that is it
n/a_tune
262
4g93 n/a full race,, what type of race?? drag..time attack,endurance or track race??:proud::thefinger:
cooljas
523
Skywalker,
If you dont mind can u tell me where to get the 6puck twin plate clutches for 4G93NA?Also the double valve spring...thanks
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
Skywalker,
haha... no idea... jz a racing clutch suggestion... can opt for single plate 4puck also if available... i jz pakai hentam nia....:biggrin:
lae
10
currently my engine :
pnp
cable spark racing
bore piston 82 mm
crankshaft n flywheel balance
camshaft 272"
valve spring racing
thortle body 65mm
injector 360cc
ecu haltech
clutch set exxedy
lsd
what must to do for increase power , but still N/A ?
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
pnp
cable spark racing
bore piston 82 mm
camshaft 272"
valve spring racing
thortle body 65mm
injector 360cc
ecu haltech
clutch set exxedy
lsd
next up go for ignition... MSD??...
camshaft 360 degree:banghead:
wow... u want ur valve to stick open/close 24/7??...:adore::adore:
HALO! guys! need a help!
i wan to change rear drum to brake disc,so wat size or car disc brake
can use in satria 1.3, did it need to change 15inch rim? :)
