How to install FICD on DCNF40 4G15.....
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
amuroray, i installed the FICD to my car... i'm using weber dgv... i connect the F hose to the intake manifold (with a Y connector) and i left I open to suck air.... but the maximum rpm i get is only 500rpm....
when i turn the screw on top, its hose F that determines how much air being sucked in... hose I remains stable even when i turn the screw....
so, got 2 possibilities...
- my FICD faulty
- weber dgv has different FICD setup compare to DCNF (which i dun think so coz we are connecting the hose to the inlet at intake manifold)
any sifoo can help me??..
another question... the rpm increase when the FICD is sucking more or less air??.... when u close finish the valve, totally no air sucking??... mine still got abit air sucking in..... if yes, could it be the valve inside damaged already??...
AmuroRay
736
- my FICD faulty
hi sky...... connnection terbalik already..... F (upper hose from FICD) is use to suck in clean air, I is connect to intake with T-join (refer my pic 1).....:burnout:
btw,maybe will get CAI from u later....hehe:biggrin:
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
i've fixed the connection properly adi according to ur diagram... but the problem still occurs.... the rpm wont go up or down when i turn the allen key screw.... should be the FICD faulty rite??....
offtopic: yaya, can PM me whenever u want the hose...
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
no people help me geh??...
btw, today went back to the halfcut shop and tested with another FICD... result is still the same... max rpm i can set is 500rpm...
the tauke said the hose from pcv valve to intake manifold cannot leak air... if excessive air leak into it, engine will stall... means in order to increase the rpm, we need to pump more air out (instead of leaking air into intake manifold) ??.... taikor amuroray, i dun understand ler.... whats ur a/c on rpm??...
the tauke asked me to take a look at AE101 engine bay and see how the FICD works... coz those toyota FICD are from AE101... he asked me to check where the 2 hose originally run... but i dun have friend who drive AE101....
Hi all car enthusiast,
My friend's 2009 new Camry just stolen today 07 October 2009, around 4-6pm!!!
Crime information:
Location: The Mines Heritage Condo (The car park at the car park downstairs), Serdang area
Time: 4-6pm
Model: 2009 Camry 2.4 Full specs
Color: White
Number Plate: XXXBBBB
The guard is really useless, I guess he see the thief drive the car out just like that??
All car enthusiast if you see this car please call. Hope all...
