hytech headers/extractors for b series
cnex
30
I wonder if any of you guys out there heard of the hytech headers???
Anyone using them?? Are they as good as japanese ones?
J101
1,304
malaysia
yes i have heard of it. never seen anyone using both production or custom version in malaysia yet.
they are much expensive than the brand new toda full race headers.
it should be better since they custom to suit your application. never heard anyone called mugen or toda to custom their headers so far.
cnex
30
I heard that these headers are actually a hybrid of 4-1 and 4-2-1 giving you both acceleration and top end, anybody has any idea about this?
xxxx
1,816
from tpr,
HyTech Exhaust - TEST SET 01
At this point, you've already seen the graph on the previous page, and you've probably already done the math. Yes - we're showing a 51.1hp increase. Yes, that's highly unlikely and it made everyone... uncomfortable. We have to note that the HyTech unit is marketed as a "racing" header and will not fit with the power steering and air conditioning compressor intact; these were removed for our testing of the header. Still, our test procedure stayed the same, our test platform stayed the same, and the multiple runs we did were all repeatable to within 3 horsepower of each other, with power curves following the same lines each time. Like the other headers, the HyTech unit increased low-end torque production to such a point as to negate the effects of the "pre-VTEC" dip in the powerband, and it also straightened the graph to make the powerband more linear after that point. Like the other headers, the standard test procedure was followed, with the same extension pipe mounted onto the header. DISCLOSURE: The pipe was provided to us by HyTech as they were concerned about the possibility of a loss of power due to the relatively short runner length from the collector to the header's exhaust gas exit point. Now, one could easily conjecture that the pipe benefited HyTech the most because they designed it, and that would be true. However, that fact doesn't prove that this was an act of collusion; it rather suggests that HyTech might know a little something about header design that we don't know - hence, their polite suggestion that we use the pipe on all the header tests. Given the design of the pipe (essentially a long test pipe or straightpipe) and the fact that the tests were conducted pragmatically and without bias, we wondered if it might be possible that the header wouldn't make as much power if attached to a complete exhaust system. When we brought all of this information and the dyno charts to our peers and a few industry tuners, however, they all had different opinions...
HyTech - Test Set 02
This time around, the HyTech unit made about 3-5 additional horsepower between 3400-4300rpm, then slowly produced more power over stock from about 6300rpm to redline. In all other areas of the graph, the power gain was negligible. Peak power production rose from 160.4hp to 168.5hp
Aside from the revelations we had about "standardized" testing procedures, we also amassed a mountain of data. And, in our current "peak horsepower" world, if a winner was to be chosen from that data by maximum peak horsepower gain alone, the winner in both test sets - as clearly identified by the graphs - is HyTech Exhaust.
crower75
5,000 RPM
5,410
TeAM C.R.D
"We have to note that the HyTech unit is marketed as a "racing" header and will not fit with the power steering and air conditioning compressor intact; these were removed for our testing of the header."
aiiseehh.......goodbye !!.....
shiroitenshi
3,676
170
Hytech are race headers.. long straight primaries exiting from the head.
Cost is forbidding too.
Get something easier on the wallet, exhaust isn't the only way to free up power. :P
zamrioo2
180
2
3,018
mr shirotenshi...
is there any good local made extractor as well as wellknown branded which u could suggest to us...?
shiroitenshi
3,676
170
mugen B18c is one I've always liked.. but very hard to find one in a pristine condition.
I think it's also one of the popular choices for hondas running in the SuperSixteen classes at sepang.
There's a local made one, but never tested yet.. I'm sure you've seen it as well... I know the guy that makes it, but his idea of making the primaries smaller doesn't seem to say much about it.
Well, depends on if I can get a unit to test..
chris2000
1,114
24
I have NEW J's Racing 4-2-1 extractor.
I have a USED DC Sport Race 4-1 extractor but dented at the bottom. But it still made 200whp! hehe...
PM me if interested
budin99
429
2
Anyone can tell about Spoon 4-2-1 header? I think I read somewhere legendary 5050 also used dis extractor too. And another question, why spoon always come without "spoon" mark??
J101
1,304
malaysia
i think there will be more questions if a particular branded extractor is good or not? hmm.
xxxx
1,816
shiro,
i just saw a 99% perfect condition b18c mugen 4-1 extractor not so long ago.
but the price......haha......
Similar threads   Forum
Honda
  Similar Threads
Honda
Hi everybody.
i just change the steering wheel to a sporty one (12 inch size) yesterday.
the result, feel heavy when turning....like no power steering lah.....
what happen actually? the steering wheel is light, is this cause the heaviness?
what can i do to solve these beside changing back to stock steering?
One more thing, need to put grease or not on the bosskit?
