NBTD - I'm BORED
Mine is unknown brand and I bought the whole thing for RM100. I'm thinking if it's worth fixing or not. hahahaha
If too many parts needs replacing then it might cost more than the compressor or can get a new cheap one. Then again u will know how to fix the comp in the future if u repair the current one.
maybe i can keep this one for spare parts. hahaha.. how much for a good one these days?
starts at 1500 for Swan 2 piston electric motor driven comp with big tank. Will exceed 2000 if u opted for a Robin gasoline engine instead of electric motor which will allow the comp to operate where no electrical supply is available.
One piston recharged the air slower but for me if its coupled to a big tank like 50l, its good enough for me.
My tank is small (forget my tank capacity) like the one u get when buying RM200-300 air comp. U will lose sufficient impact power quickly and with one piston charging it, some pause/rest is needed between few multiple use.
it depens on your usage really. There is also the max air pressure. if i recalled correctly the air pressure valve can be change so u can holder higher air pressure but i am not sure on the saftey aspect.
Reactions: Izso
Ah.... I checked the price for a new one for the version I have, it's about 380 only. Let's see how it goes. If the service is cheaper than that - I'll just do that. OTherwise this thing is scrap metal.
BTW...whats wrong with the thing?
the valve and the meter on the top doesn't work and the air doesn't seem to open up
a stuck air valve thing. normally it will happen if the tank is not drained of fluid every now and then causing dirt/rust/gunk sticking at the valves.
Remove the fittings and get replacement. If u are lucky the gauge is still ok.
my comp have 2 outlet ( useless really when the tank is too small ) and one of them is broken like yours. already fixed but forget the cost. Should be well below RM100.
Wait...try clean the fittings internal first.
After reading your previous post was about to say this also, try cleaning, maybe some dirt stuck there......lol
He is probably at it now.
Then when its fixed he will complain to himself on why its so simple but he did not try it earlier, he wonders what good times he could have had with the compressor working.
why is the whole thing covered in some sort of oil that's kinda sticky? Hmm.. I think the first thing I'll do is wash the whole thing, dismantle the whole motor on top and then see what to do from there.
btw how do I drain the thing? I think I hear water inside. hahahaha
there must be a drain plug at the bottom of the tank. check what material is it as somes with copper plug which deforms easily when u grip using pliers to loosen them. Dont be too happy screwing it all the way out if there is pressure in the tank as u will end up looking for the drain plug. I bet when u loosen the drain plug a bit, nothing will come out as gunk has blocked the opening. u will need to unscrew slowly or use a cloth to cover it and watch leech like substance flow out then suddenly a spray of either water or gunk mess up your floor.
Wash it but dont dismantle first. Since yours is electric driven too then dont be too happy when washing it with water.
After washing, remove the air fitting and soak them in degreaser or petrol or diesel and cleaned them. Re install and see if it works.
If it does works them fill the tank up, check for air leak if any. If no air leak then search for oil leak. The whole thing should not be covered in oil if there is normal oil leak unless the tank is not drained for some time and the air oulet is clogged causing it to spray air mixed with oil all over the place.
Reactions: Izso and vr2turbo
Hi there,
I am planning for the following Yokohama tyres for my 2 cars, one using 195.55.15 and another is 180.60.14
After some research online and offline, found that Advan Neova AD07 only have size for my 195.55.15 while AVS ES100 have sizes of both.
Also known that the UTQG for AD07 is 180 AA A and ES100 is 280 AA A. If I am going to take AD07 for the 15" and ES 100 for the 14", would this be my good choices?
Need your experiences on both tyres model in terms of dry, wet, treadwear...
