Lancer is going Manual
Mitevo7
1,456
179
Dear All,
I am pleased to announce my Lancer will be going manual in about 2 weeks time. The faithful CVT remains excellent till this date after 12 years of service, i decided i needed something more engaging without changing another car. Lancer is my daily drive car so driving it manual is going to be a challenge for first few weeks. However i believe it would make me a much better driver.
From there, turboing the engine should not yield any much issue to the MT compared to CVT. Stay tuned.
Reactions: Needles Tosay
lsm1991
1,469
185
tu pump jaga sikit, not sure if theres any alternatives.
also the cvt can actually take some beating, abit not over long periods
Mitevo7
1,456
179
Upper clutch pump i am considering to upgrade it, if the cost is not too high. As a car guy, i think i am incomplete without a manual car in my fleet :rofl:
Dear All,
What gearbox you opting for? Taken from where?
Mitevo7
1,456
179
Get normal clutch, if not left leg sure need work out.......lol
Getting normal Daikin Exedy clutch kit and pressure plate. I use this for training first before going hardcore on anything
Mitevo7
1,456
179
How you bypassing the TCU? And the ECU? You going to transplant a whole halfcut?
Tapping few wires, bypass the TCU and install manual map into the ECU then call it a day.
Mitevo7
1,456
179
Phew you really do love your Lancer eh!
Not same with the manual Inspira 1.8?
Inspira gearbox gear ratio is shorter, rev will be pretty high on highway. Galant Fortis on the other hand, has different gear ratio, hopefully the rev will be lower on cruising while giving out good performance.
hi all...
i got many spot got rust on the car body...
can DIY ?
i thinking...
1. use sand paper or machine sander/dremel with wire mesh bit to remove rust
2. take it to shop with welding machine ask them weld ( what shop got? exhaust shop can ar? )
3. use the putty ppl use for car body to cover it back
4. use find sand paper to make the surface flat again
* But will looks ugly lar .. the putty is visible without new paint
.. but can save cost
how u think? can work or...
