those maybe doesn't have primer.... just sand, putty, spray... rolled out and dry under the sun... dust is pearl metallic effect. LoL...My JB area here see alot of these promotion. 1.2k spray outside.
Sound too good to be true. My wira paint shop rm2.7k.My JB area here see alot of these promotion. 1.2k spray outside.
That 1.2k is normal price in Melaka too. Not sure what process involved, maybe just like what minibeany said. Once of my colleague just painted his wira around that price too. Looks ok to me but not sure how long will last.Sound too good to be true. My wira paint shop rm2.7k.
Rm1.2k you can think the quality of the paint....primer....all cheap one so.....sure the whole price will be cheap.Sound too good to be true. My wira paint shop rm2.7k.
Depend on how ur car exposure to nature.Rm1.2k you can think the quality of the paint....primer....all cheap one so.....sure the whole price will be cheap.
How long can it last that is the question.
Depend on budget i guess?I am just wondering abt paint quantity requirement for my waja...how many liters of clear coat will it need?
Thinking of painting it with a fresh coat of silver and sealing it with glasurit clear coat.
Most area are still good...only the C-pillar,boot and roof edges are showing its age by turning into Nardo Grey-like silver..hahaha.
I have been teaching some wira owner on the oil cap. Is probably the rubber gasket is old or worn. What you can do is centralized the cap then reverse lock a bit, if helps to tighten it a bit more. Try it, so far mine on the VR is ok, so are a few wira owners who did it.....Wire update
After my car had done top overhaul for 4month the car is running good.
But sometimes when I open my hood and do some cleaning, I saw some dry oil around the oil cap. Not sure is the oil cap is worn out of other thing...
My colleague told me that the piston ring might worn out bla bla bla something like that causing the oil leak out from the oil cap.
I will buy a new oil cap and see does the problem still come out or not.
Or...just cut a motorcyle tube to size. I used that for a very long time on my Campro before my little brother replace it when he was using the car.I have been teaching some wira owner on the oil cap. Is probably the rubber gasket is old or worn. What you can do is centralized the cap then reverse lock a bit, if helps to tighten it a bit more. Try it, so far mine on the VR is ok, so are a few wira owners who did it.....
Okok,I will try it later.I have been teaching some wira owner on the oil cap. Is probably the rubber gasket is old or worn. What you can do is centralized the cap then reverse lock a bit, if helps to tighten it a bit more. Try it, so far mine on the VR is ok, so are a few wira owners who did it.....
Motor bike tube cannot stand oil, need to keep clean. Once oil gets to it, it expands....Or...just cut a motorcyle tube to size. I used that for a very long time on my Campro before my little brother replace it when he was using the car.
Uncle Vr way work.I have been teaching some wira owner on the oil cap. Is probably the rubber gasket is old or worn. What you can do is centralized the cap then reverse lock a bit, if helps to tighten it a bit more. Try it, so far mine on the VR is ok, so are a few wira owners who did it.....
Yup, VR, my Hyundai also, having Mitsu engine also use same method, no oil leak from cap.......lolUncle Vr way work.
