KHNG940413
668
56
johor bahru
Wira update
My car suddenly have an issue.
When I step on the pedal going to around 3k rpm my player will juz restart it self. Anybody know what is causing this?
Had check the fuse all ok no burn one.
While idling when rev to high rpm the player will also restart it self.
Wira update
you better take out the player/hu and check to see if you have a short somewhere. EIther you have a grounding issue or your HU is going to rosak soon
KHNG940413
668
56
johor bahru
Normally to save cost, spray same color, so just spray outside good enough. But if change color best to spray inside also....
Last time when I cement my mivec bonet. I juz ask the boss if spray the whole car the same colour how much.
He say Around 2k need around 2week time
Yup, possible.
Best way is to solder all wire join then use heat shrink but most shop just twist join then use black tape. Few years down the road the joint can becomes loose, so does the wiring tape (esp those cheapo tape).
Reactions: sweelt
If can be trusted to do a good job, longer is better. This is for the putty to dry hard, if not you may get settling problem, meaning if they do it fast, later when putty dry it shrinks or settle then can see sandpaper marks. Another will be the clear coat they use, that is why prices can defer a lot. I heard from a friend some used car people spray only around RM1k, exterior only fast job, can guarantee later only will get settling problem......lol
KHNG940413
668
56
johor bahru
Me & my friend had open and check. Didn't had any wire short. Mayb is grounding or my player is going to kong soon.hahahhaah
minibeany
598
102
543
yeah... also the sanding part also important... doing fast and not totally dry will has issue with bubble later.
1K... they probably you the cheapest paint in town which cost RM30 / can. Only need 6 cans for a sedan car.
Wira update
My hyundai almost same problem, but the HU switch off is due to hard bump, then will come back on in a while. Could be loose wire or HU internal got problem.......lol
KHNG940413
668
56
johor bahru
today I juz try. While crusing at highway at 3k rpm,the player will juz black out until my rpm drop back to 3k below.
I think really is my player got problem. Will ask my friend lend me a player slot in and check is it really my player rosak or wire issue
KHNG940413
668
56
johor bahru
My JB area here see alot of these promotion. 1.2k spray outside.
newbie here , i jus get 1 nissan bluebird u910 1980 wit sr20det ......
get tis car for me is to plan start play drift but....
i found tat body got alot of problem ..... espiacially the car btm ....
ofcoz is RUST ...... CRACKED .... STEEL PART BENT .....
any 0 any1 know any workshop in KLANG/SHAH ALAM area can help me to solve tis problem .......
pm me ....THANKS......
