Humble DIY Repairs On My Car
check your oil pump. I increased to almost max flow as we are not expert and does not know how hard some trees are.I Learn that the hard way when cutting a rambutan tree to smaller pieces after the tree was struck by lightning. Burnt the chain, after that oil pump fail.
Parts are cheap and available online.
Wow, chain saw also a lot to learn........ :smokin:
leinnz
333
57
3,028
Yup I have tried to be careful by censoring out my car number plate. So even if I go over the limit not easy to trace. Sure they can check through my face but it is easier for police to catch people just on the road lol.
next time say test ride in new mexico roads. this is wat most US youtubers mention when they test their car to the limits.
Just like car engine but smaller scale.
If cant start check for spark..Most of the time fuel is ok due to design of the carb which does not hold fuel. If no spark then change the coil. If got spark then check fuel supply where it only got fuel screw for idle and high rev.
If chain runs at idle then check clutch. Clutch spring is worn out.
If cant full throttle despite pushing the throttle to the max then check carb linkage.
Always check chain oil level to prevent damage to chain and bar. Its like checking engine oil level on our car engine.
Now got fuel injected saw and battery powered saw.
Best part is change of engine block does not require Puspakom inspection and JPJ approval..hahah
Reactions: sweelt
where did you buy the EPAuto spillproof funnel from? I've been looking for something like this.
Also I'll be surprised if no one talks about distilled water vs tap water. hahaha
I am like him use tap water with coolant.....lol
MEngineer
Nov 11, 2012
17
9
503
I bought it from US while I was there in country. Here you can find it too
I recall Lazada or Shopee has it got RM140. Tried to find but no there, if I come across I will post here again
i remembered I did saw a pic that shows a kancil with the 1300cc K3-VET engine. I would like to ask is that really possible? No problem with the JPJ?
So one K3-VET + installation worksmanship is how much? I also need BOV, intercooler, turbo timer, piggyback ecu remap and all this dashboard meter thingie.....
So if we can install the engine, what about the gearbox? can install also? I wondered if it has CVT..... Also I would like to ask if we can strengthen the gearbox and install...
